Re: Server runtime template for WebSphere 5.1 [message #177536 is a reply to message #177503] |
Sat, 19 August 2006 05:54  |
Originally posted by: graymagi.gmail.com
I already have Rational Application Developer. It's overweight with
functionality I don`t need and also based on 3.1 version of eclipse
(plug-ins that I really need won't work with that version). May be there
is a way to extract plug-ins responsible for interactions with WebSphere
5.1 from IBM RAD and make them work with eclipse 3.2? All i need - is
ability to deploy/redeploy applications on existing installation of
WebSphere 5.1 server from IDE.
Rodion.
Angel Vera wrote:
> The adaptors were supplied to the wtp project. WTP only providided the APIs
> for the implementation.
> For extended support for WebSphere you may need to look into IBM's tooling
> "Rodion Guschin" <graymagi@gmail.com> wrote in message
> news:ec5cgb$1op$1@utils.eclipse.org...
>> Thanks for reply,
>> Yes, that i was talking about. It`s strange, that for WebSphere 6.0
>> there is such adapter, but none for v5.1. I thought that some third
>> party plug-ins may supply this feature - any suggestions?
>> Rodion
>> Angel Vera wrote:
>>> I am assuming you are refering to the Server Adapters, which is the type
> of
>>> server that you can create. If that is what you are referring to, then
> the
>>> answer is no. There is other server types that you can use, Tomcat...
> etc..
>>> check out the Link at the top left of the Server Creation window.
>>> "Rodion Guschin" <RGuschin@computel.ru> wrote in message
>>> news:ec4tuk$o4t$1@utils.eclipse.org...
>>>> Hi all, is Subj exists for eclipse 3.2 somewhere? There is only
>>>> templates for WebSphere 6.0 runtime.
>>>> Rodion
FUDForum. Page generated in 0.04291 seconds
