CircularRedirectException for Eclipse Mars Repository [message #1774655] |
Wed, 18 October 2017 06:57  |
Hi all,
in my fresh Eclipse Mars installation, I get the error attached when trying to contact the mars repository.
My system is behind a proxy, but the internal web browser works with the current proxy settings (native), as do other repositories.
I already searched for similar errors and tried the following proposals with no success:
- Delete the cache folder
- Reload the repository
- Add argument for ipv4 stack
- Manual proxy configuration
Due to an eclipse plugin that requires eclipse mars, I have no options of trying a different eclipse version.
The system is Windows 7 Enterprise x64 and is running in a virtual machine.
The host system is Ubuntu 16.04 on which an eclipse indigo is running well (installed by package manager). On the same system, a manual installation of eclipse oxygen suffers the same error than the eclipse mars installation in the windows 7 vm.
Therefore, it clearly seems to be a configuration problem. The package manager seems to have adjusted something that eclipse needs - but I have no clue how to find it out.
Any hints?
Nicolas
Attachment: .log
(Size: 67.96KB, Downloaded 180 times)
Re: CircularRedirectException for Eclipse Mars Repository [message #1774684 is a reply to message #1774681] |
Wed, 18 October 2017 11:22   |
Ed Merks wrote on Wed, 18 October 2017 15:06I'm not sure how bad this part is but it seems proxy related:
!ENTRY org.eclipse.ecf.provider.filetransfer 4 0 2017-10-18 12:34:21.358
!MESSAGE org.eclipse.core.runtime.Status[plugin=org.eclipse.ecf.provider.filetransfer;code=4;message=Warning: Platform proxy API not available;severity2;exception=java.lang.NullPointerException;children=[]]
!STACK 0
at org.eclipse.core.internal.net.ProxyManager.tryGetURI(ProxyManager.java:322)
Yes, I also think it is proxy related
Ed Merks wrote on Wed, 18 October 2017 15:06Does the embedded browser within the IDE function?
Yes, it works, as do other repositories!
Ed Merks wrote on Wed, 18 October 2017 15:06I'm a bit concerned that it could be a server problem with transparent mirroring: https://bugs.eclipse.org/bugs/show_bug.cgi?id=515596#c9
Perhaps attach your log to that Bugzilla and ask if there is a server problem...
I don't know what transparent mirroring means, but I assume it doesn't matter if I know it... :D ... but, the bug report is closed already - should I still attach my log there?
Thank you for your help,
Nicolas
FUDForum. Page generated in 0.13557 seconds
