Standalone program : error loading old model (ns=http://www.eclipse.org/uml2/2.1.0/UML) [message #1774659] |
Wed, 18 October 2017 07:27  |
Hello
I work in a stand-alone tool that transforms UML models. I setup my environment using UMLResourcesUtil.init.
Everything worked nicely, until one of my users tried to transform and old UML2 file (created with Topcased, namespace http://www.eclipse.org/uml2/2.1.0/UML), and
there I got an exception loading the resource :
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: platform
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.uml2.uml.internal.resource.UML212UMLResourceFactoryImpl.createResource(UML212UMLResourceFactoryImpl.java:96)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:434)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
at Main.main(Main.java:60)
Debugging the code, I noticed that the good content type is registered for namespace http://www.eclipse.org/uml2/2.1.0/UML, so it finds the good factory UML212UMLResourceFactoryImpl. But the factory tries (see code below) to load an ecore2xml file with an platform:/plugin URI that is not mapped by
UMLResourcesUtil
Ecore2XMLRegistry ecore2xmlRegistry = new Ecore2XMLRegistryImpl(
Ecore2XMLRegistry.INSTANCE);
ecore2xmlRegistry
.put(
UML212UMLResource.UML_METAMODEL_NS_URI,
EcoreUtil
.getObjectByType(
resourceSet
.getResource(
URI
.createURI("platform:/plugin/org.eclipse.uml2.uml/model/UML21_2_UML.ecore2xml"), //$NON-NLS-1$
true).getContents(),
Ecore2XMLPackage.Literals.XML_MAP));
I think the same problem will happen for XMI and CMOF files, as all the factories have similar code.
As a workaround, I have added in my program a mapping to the ecore2xml models directory :
* This is the workaround for loading legacy uml2 models.
* Notice that the mapping is added to the global registry, because the factory is trying to load
* the ecore2xml model in a private resourceSet (not in ours)
boolean workaround = true;
if (workaround) {
try {
URI umlMetamodel = URI.createPlatformPluginURI("/org.eclipse.uml2.uml/model/UML.ecore",true);
URL umlMetamodelLocation = UMLPlugin.class.getResource("/model/"+umlMetamodel.lastSegment());
URI umlMetamodelPhysicalURI = URI.createURI(umlMetamodelLocation.toURI().toString(),true);
URIConverter.URI_MAP.put(umlMetamodel.trimSegments(1).appendSegment(""),umlMetamodelPhysicalURI.trimSegments(1).appendSegment(""));
catch (URISyntaxException ignored) {}
the workaround is working. So the question is if this is a bug (some corner case not considered in UMLResourcesUtil.init) or am I missing the invocation of some other
method responsible of doing this mapping?
I join my test program (with the workaround) and a test file, I have tested in UML2 5.2.4 (but browsing the 5.3 sources I see the same code).
Another, unrelated, question, is there a way to save the resource with the old namespace and XMI format? currently when I save the resource (even using the UMLResource.UML_2_1_0_CONTENT_TYPE_IDENTIFIER content type), it is automatically upgraded to the new metamodel (http://www.eclipse.org/uml2/5.0.0/UML). See
the end of the attached Main file for my saving code. My user has some legacy tool that works only with topcased so it will be good if I preserve the format. My tool
modifies the model, but mainly by adding annotations and stereotypes, no structural changes.
Thanks for the help
German Vega
Attachment: Main.java
(Size: 3.44KB, Downloaded 263 times)
Attachment: model.old.uml
(Size: 0.32KB, Downloaded 351 times)
[Updated on: Wed, 18 October 2017 07:34] by Moderator
Re: Standalone program : error loading old model (ns=http://www.eclipse.org/uml2/2.1.0/UML) [message #1774750 is a reply to message #1774748] |
Thu, 19 October 2017 06:25  |
One of my integration attempts for UMLResourcesUtil used a full classpath scan; rather expensive. I think that you will find that UMLResourcesUtil.mapUMLResourceURIs is the much more pragmatic equivalent for just a path of interest. You have uncovered another path of interest, so perhaps the need for EcorePlugin.ExtensionProcessor would go away with another UMLResourcesUtil.mapUMLResourceURIs call or two. Patch welcome.
Ed Willink
FUDForum. Page generated in 0.07283 seconds
