Home » Modeling » TMF (Xtext) » Linking XCastExpression to a "toX" function
Linking XCastExpression to a "toX" function [message #1774571] Tue, 17 October 2017 08:54 Go to next message
Dear all.
In my DSL, I would like to enable operator overriding for the cast expressions.
My idea is:
Let the following code:
var x = ...
var y = x as String
var z = x as Y
"x as String" should be map to the Java code "x.toString()".
"x as Y" should be be map to the Java code:
* "x.toY()" if this instance function is defined and accessible,
* "toY(x)" if this class function is defined and accessible,
* "(Y) x" otherwise
My question is: what are the typical classes within Xbase to be extended for enabling this behavior?
I think about:
* XbaseCompiler for generating the Java code,
* DSLValidator for changing the validation test.
What else?
Thank in advance.
Stéphane.
Re: Linking XCastExpression to a "toX" function [message #1774572 is a reply to message #1774571] Tue, 17 October 2017 08:56 Go to previous messageGo to next message
XbaseCompiler. Possibly Validator. Possibly FeatureScopes
Xbase Type Computer. Maybe XExpressionHelper
Re: Linking XCastExpression to a "toX" function [message #1774574 is a reply to message #1774572] Tue, 17 October 2017 09:02 Go to previous message
Thank you, I will start to work based on this list of classes.
Stéphane.
Previous Topic:Expression Language: Using ".*" in combination with Decimal Numbers
Next Topic:Xtext Standalone: Add/Remove/Modify resources
Current Time: Fri Jul 25 11:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.90652 seconds
