Re: Xtext 2.13.0.RC1 is available [message #1774595 is a reply to message #1774387] |
Tue, 17 October 2017 12:01   |
Sebastian,
The before or 'fast' compiles/builds were on the following software/hardware versions (all on Windows 10 64-bit on an i7-3770, with plenty of RAM 16GB, no swap space and an SSD drive):
- The standard Oracle Java 8-144 64-bit jdk
- Eclipse Oxygen (before recent 4.7.1a update)
- XText 2.12
On the same hardware, I went to Java 9/Eclipse 4.7.1a and Xtext 2.13.0.RC1 (as Christian was asking on feedback on that).
I think most of my problems arise from the Jigsaw changes, and that Eclipse is not quite ready for them. Eclipse is acting very weird: I see errors marked in my source file editor windows (quite often module-info.java), but at the same time there are no errors reported in the "Problems" view.
I think that Eclipse's 4.7.1a build goes through too many rebuilds of files that it thinks still need a rebuild, that in actually are already in order. I have to now force to proceed lauches with 'errors' in my project, while in actuality there are no errors.
As for asm: I removed that from eclipse.ini as Christian advised me to do as it really gave trouble on Java 9 with it, but if that caused the slowdown of the mwe2 going from 34sec to 44sec than I'm OK with that.
The real problem is the entire projects rebuild that takes place by eclipse after mwe2 runs.
Do you still want me to report issues on eclipse/Xtext core, because I think these are Eclipse Jigsaw issues not related to Xtext per se.
Re: Xtext 2.13.0.RC1 is available [message #1774609 is a reply to message #1774387] |
Tue, 17 October 2017 14:06   |
Yes, I could easily reproduce. Here are the steps on Windows having only a Java 9 JDK on it:
1) From the New Projects dialog I chose the XText Arithmetic's example
2) Trying a straight .mwe2 build does fail
3) In the build.properties remove the asm-entry as per Christian's advise
4) Build mwe2, this is fast
Now to make it slow do the following:
5) Go into each project's BuildPath,(I started at the top project, working my way down to ...ui.tests project) and remove the jre-1.8 library reference, followed by an 'Add Library...', choose System Library, then the jre-9 library that you see.
6) From the bottom project I worked up through the projects with this: Open up the BuildPath dialog once more, but now go to the Java Compiler Settings, enable project specific, and set JDK Compliance to Java9, and Apply that. These applies trigger re-builds. When doing this at second project from the bottom, things already get immensely slow. Continue with this to make things really slow.
I didn't even try adding a module-info.java on this example project, but I bet that you would see Eclipse's error markings fail on things you export. (not reported in Problems as described before).
Hope this helps,
Aart
Re: Xtext 2.13.0.RC1 is available [message #1774698 is a reply to message #1774695] |
Wed, 18 October 2017 12:50  |
Thanks Ed,
I don't expect with the new Module System that everything is perfect yet. I understand that it is a big impacting change. I'm old enough that I can recall the days of Java 1.1 (and the computer industry before that time), and I haven't experienced such an impacting change as Jigsaw in all those years. I do want to participate with reporting and resolving issues, as I'm here with Xtext, and I also just filed a JavaFX issue under Java9.
It is funny that you also mentioned jUnit5. I'm still on 4.12, and I was thinking of trying out jUnit5 this weekend. Maybe I'll first read the forums on that one, to save myself some time.
Thanks again all of you for the suburb work.
FUDForum. Page generated in 0.05887 seconds
