checkbox column double-click event [message #1774420] |
Fri, 13 October 2017 19:21  |
There are two columns
I added checkbox to column 0. And registered double-click event. When column 0 double-clicked event not occurred but for column 1 double-click event occurred. I tired too on TreeGridWithCheckBoxFieldsExample.java I registered double-click event
gridLayer.addConfiguration(new AbstractUiBindingConfiguration() {
public void configureUiBindings(UiBindingRegistry uiBindingRegistry) {
uiBindingRegistry.registerFirstDoubleClickBinding(new CellEditorMouseEventMatcher(GridRegion.BODY),
new IMouseAction() {
public void run(NatTable natTable, MouseEvent e) {
int rowPos = natTable.getRowPositionByY(e.y);
int bodyRowPos = LayerUtil.convertRowPosition(natTable, rowPos, bodyDataLayer);
System.out.println("double click ok");
Result is same. Not double-click event occurred for column 0. Column 1 is ok
How can I find a solution?
Re: checkbox column double-click event [message #1774479 is a reply to message #1774420] |
Mon, 16 October 2017 04:38  |
The issue here is the checkbox painter / editor. Why do you use the CellEditorMouseEventMatcher that performs a check for an editor? Isn't a MouseEventMatcher enough?
uiBindingRegistry.registerFirstDoubleClickBinding(new MouseEventMatcher(GridRegion.BODY, MouseEventMatcher.LEFT_BUTTON),
FUDForum. Page generated in 0.06801 seconds
