Home » Modeling » OCL » OCL generator and EMF super types
OCL generator and EMF super types [message #1774435] Sat, 14 October 2017 06:25 Go to next message
Hi all,
I detect a strange behavior during the EMF generation when I have OCL constraints generated in the EMF java code.
So, I have a first metamodel
package metamodel : metamodel = 'http://metamodel'
	class ClassA extends Class
		attribute name : String[?];
		invariant name_inv: name <> 'test';
	class Class;
In the associated genmodel, I add this annotation
  <genAnnotations source="http://www.eclipse.org/OCL/GenModel">
    <details key="Use Delegates" value="false"/>
  </genAnnotations>
EMF generation works perfectly, and I code of my name_inv is generated:
public boolean name_inv(final DiagnosticChain diagnostics, final Map<Object, Object> context) {
		 * inv name_inv:
		 *   let severity : Integer[1] = 'ClassA::name_inv'.getSeverity()
		 *   in
		 *     if severity <= 0
		 *     then true
		 *     else
		 *       let result : Boolean[1] = name <> 'test'
		 *       in
		 *         'ClassA::name_inv'.logDiagnostic(self, null, diagnostics, context, null, severity, result, 0)
		 *     endif
		final /*@NonInvalid*/ Executor executor = PivotUtilInternal.getExecutor(this);
		final /*@NonInvalid*/ IntegerValue severity_0 = CGStringGetSeverityOperation.INSTANCE.evaluate(executor, MetamodelTables.STR_ClassA_c_c_name_inv);
		final /*@NonInvalid*/ boolean le = OclComparableLessThanEqualOperation.INSTANCE.evaluate(executor, severity_0, MetamodelTables.INT_0).booleanValue();
		/*@NonInvalid*/ boolean symbol_0;
		if (le) {
			symbol_0 = ValueUtil.TRUE_VALUE;
		else {
			final /*@NonInvalid*/ String name = this.getName();
			final /*@NonInvalid*/ boolean result = !MetamodelTables.STR_test.equals(name);
			final /*@NonInvalid*/ boolean logDiagnostic = CGStringLogDiagnosticOperation.INSTANCE.evaluate(executor, TypeId.BOOLEAN, MetamodelTables.STR_ClassA_c_c_name_inv, this, (Object)null, diagnostics, context, (Object)null, severity_0, result, MetamodelTables.INT_0).booleanValue();
			symbol_0 = logDiagnostic;
		return Boolean.TRUE == symbol_0;
Now, I have this second metamodel:
import metamodel : '../../metamodel.emf/model/Metamodel.ecore#/' ;
package metamodel2 : metamodel2 = 'http://metamodel2'
	class ClassB extends metamodel::Class,metamodel::ClassA;
So, I have this diagram:
index.php/fa/31004/0/
When I generate the EMF model code of the second metamodel,
I obtain errors on ClassBImpl class saying that:
The type ClassBImpl must implement the inherited abstract method ClassA.name_inv(DiagnosticChain, Map<Object,Object>)
To resolve it, I add the unimplemented method using the quick fix.
HOWEVER, when I edit my second metamodel by changing the order of the extended classes,
	class ClassB extends metamodel::ClassA, metamodel::Class;
the generation works perfectly without errors.
So, my questions are:
Is that a OCL generation bug?
Otherwise, Is the order of extended classes important?
and must conform to a specific representation enforced by EMF and OCL ?
[Updated on: Sat, 14 October 2017 06:42] by Moderator
Re: OCL generator and EMF super types [message #1774437 is a reply to message #1774435] Sat, 14 October 2017 08:04 Go to previous messageGo to next message
I'm inclined to blame EMF2Java. Java only supports one super class and many super interfaces but EMF models many super classes and has to re-implement concrete functionality from non-first superclasses. By putting the 'better' ClassA second you required EMF to re-synthesize ClassA::name_inv that was only inherited as an interface into ClassB::name_inv.
Hm. The OCL2Java code generator could understand this limitation and re-synthesize for you. Could you attach a small repro to a Bugzilla that I might get round to. Cannot promise to do so soon since you have an easy workaround.
Ed Willink
Re: OCL generator and EMF super types [message #1774443 is a reply to message #1774437] Sat, 14 October 2017 13:44 Go to previous message
Thanks Ed for your feedback.
please refer to the following link https://bugs.eclipse.org/bugs/show_bug.cgi?id=526041
Previous Topic:Programmatically run OCL queries with multiple meta-models produces unknown type errors
Next Topic:Is is possible to install OCL without installing UML?
Current Time: Tue Nov 04 09:54:58 EST 2025
Powered by FUDForum. Page generated in 0.04880 seconds
