Home » Newcomers » Newcomers » "Unknown constant pool type 19" during Java 9 build with module
"Unknown constant pool type 19" during Java 9 build with module [message #1774368] Fri, 13 October 2017 07:28 Go to next message
I created a simple Java 9 hello world application (an example is here https://github.com/CodeFX-org/demo-jpms-hello-world). Whenever I declare a module, the Java builder fails with the following message:
Errors running builder 'Java Builder' on project 'demo-jpms-hello-world-master'.
Subsequent tries to run the hello world program naturally fail, the error message is as follows:
Error occurred during initialization of boot layer
java.lang.module.FindException: Module org.codefx.demo.jpms_hello_world not found
Commenting out all content of module-info.java makes the builder and the program execution run as expected.
At the same time, compiling and running from the command line works as expected. Using the above hello world example, this is the code that works:
javac -d target/classes $(find src -name '*.java')
jar --create --file target/jpms-hello-world.jar --main-class org.codefx.demo.jpms.HelloModularWorld -C target/classes .
java --module-path target/jpms-hello-world.jar --module org.codefx.demo.jpms_hello_world
I am running Eclipse Oxygen.1a Release (4.7.1a) on Java 9+181.
For a solution (in my case), see https://www.eclipse.org/forums/index.php?t=msg&th=1089434&goto=1774461&#msg_1774461.
[Updated on: Mon, 16 October 2017 05:53] by Moderator
Re: "Unknown constant pool type 19" during Java 9 build with module [message #1774379 is a reply to message #1774368] Fri, 13 October 2017 09:13 Go to previous messageGo to next message
You might want to post this question in the JDT forum: https://www.eclipse.org/forums/index.php/f/13/
Re: "Unknown constant pool type 19" during Java 9 build with module [message #1774407 is a reply to message #1774379] Fri, 13 October 2017 13:50 Go to previous messageGo to next message
Sorry for posting in the wrong forum, you are of course right.
Should I repost in the JDT forum or is it better if a moderator moves this thread?
Re: "Unknown constant pool type 19" during Java 9 build with module [message #1774411 is a reply to message #1774407] Fri, 13 October 2017 15:45 Go to previous message
Repost it there, then post a link to the question here, if you don't mind.
Previous Topic:Running Eclipse without JDK installed - Error: JVM shared library does not contain JNI Symbol
Next Topic:Installing Eclipse
Current Time: Sun Jul 27 09:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.07180 seconds
