Home » Modeling » Papyrus » State chart code generation?
State chart code generation? [message #1773683] Mon, 02 October 2017 15:47 Go to next message
A couple of questions on state machines:
Does Papyrus Designer even generate code from state machines? There used to be and maybe there still is, a project called Qompass that handled state machine code generation but I don't know what the relationship between Qompass and Designer is, if any.
I created a class and added a state chart to the class but the generated C++ code has no reference to the state machine.
I created an operation and method in the same class where I added the state machine. I want to add the method to the Entry behavior of a state in the state machine but I don't see a way to do this. The only option appears to be to create another operation.
And finally, are there any current examples of using state machines with C++ code generation?
Steve
Re: State chart code generation? [message #1773831 is a reply to message #1773683] Thu, 05 October 2017 04:58 Go to previous messageGo to next message
Qompass is the old name for Papyrus Software designer.
Software has support for State-machine generation which is pretty complete, i.e. supports for instance hierarchical state machines, parallel regions & history state. The state-machine code is added by a model-to-model transformation which is part of the standard transformation chain. In order to use it, you need to pass by the code generation via a deployment plan instead of directly clicking on "generate C++ code". We are aware that this is not very intuitive for the user and plan to change it, i.e. to automatically execute transformations of the default chain, even without a deployment plan.
An example state-machine can be found via File->New->Examples in the Papyrus category, then select Papyrus designer examples based on M2M transformations.
Re: State chart code generation? [message #1773865 is a reply to message #1773831] Thu, 05 October 2017 11:17 Go to previous messageGo to next message
So the only example in the Papyrus category is:
"Papyrus Designer examples based on direct code generation (no transformations)"
This is in Papyrus version 3.1.0.201709130748 under Eclipse Oxygen.1 Release 4.7.1 Build id 20170914-1200.
Is there another component I need to install?
Steve
Re: State chart code generation? [message #1774169 is a reply to message #1773865] Wed, 11 October 2017 05:17 Go to previous message
there is a feature called "Designer transformation" that you can install via the update site below or via the "Install Papyrus Additional components".
Ansgar
Update-site: http://download.eclipse.org/modeling/mdt/papyrus/components/designer/
Previous Topic:Papyrus Neon update fails
Next Topic:SysML 1.4 install error on Oxygen
Current Time: Sat Jul 26 12:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.04708 seconds
