Home » Newcomers » Newcomers » Error when opening Eclipse(When Eclipse installed repository and reopens there's a huge error)
Error when opening Eclipse [message #1774116] Tue, 10 October 2017 13:41 Go to next message
Hi all
So first time here and using Eclipse, hi! I am hoping to use Eclipse with the salesforce IDE which I installed and followed the salesforce guidance to the letter to do.
Now basically after installing from the repository and reopening I got a huge error which I have attached.
Now I am super new as in started to learn how to code so really don't understand anything. Can someone explain what I have to do in the simplest terms to get this to work? It would be massively appreciated.
  • Attachment: .log
    (Size: 255.78KB, Downloaded 138 times)
Re: Error when opening Eclipse [message #1774120 is a reply to message #1774116] Tue, 10 October 2017 14:22 Go to previous messageGo to next message
Did you look at the contents of the log file? Can you show us its contents?
Re: Error when opening Eclipse [message #1774121 is a reply to message #1774120] Tue, 10 October 2017 14:37 Go to previous messageGo to next message
Hi there Nitin
I actually did link it if you take a look. Its an attachment called .log
Re: Error when opening Eclipse [message #1774124 is a reply to message #1774121] Tue, 10 October 2017 14:50 Go to previous message
My mistake. You're using Java 9 to run an older release of Eclipse that isn't set up for Java 9 (there's over a year in between when the two were released). Check https://wiki.eclipse.org/Configure_Eclipse_for_Java_9#Configure_Eclipse_to_run_on_Java_9_VM for instruction on how to fix that. Oxygen.1a will be the first one to properly support Java 9 on release.
Previous Topic:Error message when installing eclipse ide
Next Topic:Source file management
Current Time: Fri Aug 29 19:02:05 EDT 2025
Powered by FUDForum. Page generated in 0.09130 seconds
