Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4DIAC-IDE for Raspbian(Installing 4DIAC-IDE for Raspbian)
4DIAC-IDE for Raspbian [message #1773988] Sun, 08 October 2017 06:47 Go to next message
Recently i just installed FORTE in my raspi. I also want to run the IDE in my raspi. But when i tried to it run in from terminal, it says the program isnt compatible. i downloaded the linux x86 version. Raspi itself use the arm 8. is it possible to run the IDE ? if it's possible, how do i run it ?
Re: 4DIAC-IDE for Raspbian [message #1773998 is a reply to message #1773988] Sun, 08 October 2017 16:36 Go to previous message
In order to run 4diac-ide on raspi you need an arm version for it. Per default our buildsystem currently does not build arm linux versions. In principle 4diac-ide should work on arm linux. What you could try is to build 4diac-ide from source. For that you would need an arm version for linux. Not sure of this is available?
May I ask why you would like to run the ide on the raspi?
Previous Topic:Monitoring N/A
Next Topic:Analog for beaglebone black
Current Time: Mon Jul 21 04:24:07 EDT 2025
Powered by FUDForum. Page generated in 0.03181 seconds
