Home » Newcomers » Newcomers » Eclipse 4.7 propuse update 4.8
Eclipse 4.7 propuse update 4.8 [message #1773772] Wed, 04 October 2017 09:26 Go to next message
I'm not sure to update or not.
Starting eclipse pops up update screen
asking to update to 4.8 in first line in second line is 4.7.1 xxxx.
Is this an upgrade to 4.8 or only and update of 4.7.1 xxxx ?
Can i do it ?
thx
Karlheinz
Re: Eclipse 4.7 propuse update 4.8 [message #1773790 is a reply to message #1773772] Wed, 04 October 2017 12:14 Go to previous messageGo to next message
You use the installer to install 4.7 and manually updated it to 4.8 (rather than creating a new installation for 4.8). Tell it to Skip and Remember or it will get downgraded to Oxygen.
Re: Eclipse 4.7 propuse update 4.8 [message #1773821 is a reply to message #1773790] Thu, 05 October 2017 03:00 Go to previous messageGo to next message
How can i downgrade installer ( oompth ) to Oxygen in Eclipse ?
Going to 'About Eclipse Features' i see it's installed 1.8.
Re: Eclipse 4.7 propuse update 4.8 [message #1773829 is a reply to message #1773821] Thu, 05 October 2017 04:45 Go to previous messageGo to next message
Why would you need to do that?
Re: Eclipse 4.7 propuse update 4.8 [message #1773923 is a reply to message #1773829] Fri, 06 October 2017 10:52 Go to previous messageGo to next message
I understand from your response that i have two possibility :
1. To Skip and Remember
or
2 .downgrade to Oxygen, Installer or what else
Re: Eclipse 4.7 propuse update 4.8 [message #1773945 is a reply to message #1773923] Fri, 06 October 2017 23:28 Go to previous message
I'm not sure the relation between the skip and remember part of the question and the part of the question about downgrading the updated Oomph features. Alternatively you can use Navigate -> Open Setup -> Installation and via the Properties view (double click on the "Installation" object in the "installation.setup" resource and change the Product Version to a newer one, e.g., change it from a Neon one to an Oxygen one) and then Help -> Perform Setup Tasks... will be happy with the manual Neon -> Oxygen updates you did (or if you didn't do it already, it will update to Oxygen).
Previous Topic:RE: Grove Development Boards and IDE/Java
Next Topic:Java for Windows Missing... but it's not
Current Time: Sun Jul 20 21:56:43 EDT 2025
Powered by FUDForum. Page generated in 0.08846 seconds
