Home » Newcomers » Newcomers » Eclipse error when add new project(Eclipse error when add new project)
Eclipse error when add new project [message #1773795] |
Wed, 04 October 2017 13:48  |
Hi All,
I am trying to set new project in Eclipse and I have installed following the instructions and the installation worked fine but i am having an issue when i try to create new project and I try to download the metadata.
When I do it i have the following error "unable to open custom component selection dialog eclipse"
I checked java versions and eclipse installations are everything is fine.
Is there any workaround you can recommend in order to resolve this incident?
Thanks and Regards,
Eduardo
Re: Eclipse error when add new project [message #1774050 is a reply to message #1773915] |
Mon, 09 October 2017 15:18   |
Hi Seth,
Thanks for your reply I have tried differents workarounds, my eclipse current version is 4.7.1 and kind rare since I can retreive the information for lighting and visualforce under my force.com project but when i try to retreive metadata i have the following error attached.
There are the logs:
WARN [2017-10-03 16:50:59,108] (ConnectionFactory.java:clearCache:217) - No cached connections
WARN [2017-10-03 16:50:59,119] (DescribeObjectRegistry.java:clearCache:660) - No cached describes
WARN [2017-10-03 16:50:59,122] (MetadataFactory.java:clearCache:125) - No cached metadata stubs
WARN [2017-10-03 17:21:18,428] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
LoginFault: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:21:18,443] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-03 17:21:18,451] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox': Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:21:18,482] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:22:10,041] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-03 17:22:10,097] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-03 17:22:10,102] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox': Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:22:10,147] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:24:33,875] (ComponentResource.java:loadFromFile:430) - File 'src/package.xml' does not exist
WARN [2017-10-04 09:21:09,766] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:23:25,581] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
at java.lang.String$CaseInsensitiveComparator.compare(Unknown Source)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt$1.compare(FileMetadataExt.java:37)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt$1.compare(FileMetadataExt.java:1)
at java.util.TimSort.binarySort(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt.sort(FileMetadataExt.java:418)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt.getFilePropertiesMap(FileMetadataExt.java:322)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController$1.run(PackageManifestController.java:298)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:483)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:237)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:989)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateCache(PackageManifestController.java:295)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.loadAll(PackageManifestController.java:486)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateManifest(PackageManifestController.java:173)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.getEnabledCompTypeTreeNodes(PackageManifestController.java:439)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree$ManifestContentProvider.getElements(PackageManifestTree.java:690)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:995)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:701)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1340)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:341)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:901)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:618)
at org.eclipse.jface.viewers.AbstractTreeViewer.lambda$0(AbstractTreeViewer.java:814)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:792)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:595)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:763)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1527)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:771)
at org.eclipse.jface.viewers.AbstractTreeViewer.lambda$1(AbstractTreeViewer.java:1512)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1447)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:354)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1408)
at org.eclipse.jface.viewers.CheckboxTreeViewer.preservingSelection(CheckboxTreeViewer.java:403)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree$PackageManifestTreeViewer.preservingSelection(PackageManifestTree.java:417)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1506)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:286)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1685)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree.updateTree(PackageManifestTree.java:1693)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsComposite.initialize(ProjectCustomComponentsComposite.java:116)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsComposite.<init>(ProjectCustomComponentsComposite.java:72)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsDialog.createDialogArea(ProjectCustomComponentsDialog.java:59)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsDialog.create(ProjectCustomComponentsDialog.java:156)
at org.eclipse.jface.window.Window.open(Window.java:783)
at com.salesforce.ide.ui.wizards.project.ProjectProjectContentComposite$8.widgetDefaultSelected(ProjectProjectContentComposite.java:294)
at com.salesforce.ide.ui.wizards.project.ProjectProjectContentComposite$8.widgetSelected(ProjectProjectContentComposite.java:309)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:133)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
ERROR [2017-10-04 09:23:37,231] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
at com.salesforce.ide.core.internal.utils.PackageManifestDocumentUtils.getPackageNode(PackageManifestDocumentUtils.java:157)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.getComponentTypesFromCache(PackageManifestController.java:1002)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.createModel(PackageManifestController.java:827)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateManifest(PackageManifestController.java:174)
WARN [2017-10-04 09:23:39,269] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:23:39,307] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
at java.util.TimSort.countRunAndMakeAscending(Unknown Source)
ERROR [2017-10-04 09:23:40,532] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:24:17,604] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-04 09:24:17,606] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-04 09:24:17,608] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sanbox Backup': Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:24:17,629] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:25:23,943] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:27:20,145] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:27:47,809] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:34:30,215] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:35:56,749] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:37:12,879] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:50:40,830] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-04 09:50:40,835] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-04 09:50:40,840] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox Backup': Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:50:40,874] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:53:10,078] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:54:35,931] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:56:29,610] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
Current Time: Sat Jul 26 11:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.09262 seconds
