Home » Language IDEs » Java Development Tools (JDT) » Autobuild is triggered when shutting down an Eclipse application
Autobuild is triggered when shutting down an Eclipse application [message #1773908] Fri, 06 October 2017 07:57 Go to next message
Hi everyone,
This question is related to Eclipse infrastructure and not particularly related to JDT. I don't know where else I can post.
in method AutoBuildJob#run
	public IStatus run(IProgressMonitor monitor) {
		//synchronized in case build starts during checkCancel
		synchronized (this) {
			if (monitor.isCanceled()) {
				return canceled();
		//if the system is shutting down, don't build
		if (systemBundle.getState() == Bundle.STOPPING)
			return Status.OK_STATUS;
		try {
			doBuild(monitor);
			lastBuild = System.currentTimeMillis();
			//if the build was successful then it should not be recorded as interrupted
			setInterrupted(false);
		} catch (OperationCanceledException e) {
			return canceled();
		} catch (CoreException sig) {
			return sig.getStatus();
It is checked if the Eclipse application is shutting down, the build is aborted. HOWEVER, I have been able to reproduce the behavior that though the system is shutting down, the OSGI's state is not set to STOPPING at the time the check is executed
if (systemBundle.getState() == Bundle.STOPPING) // Sometimes FALSE here even when application is shutting down!
Has anyone experienced something similar?
[Updated on: Fri, 06 October 2017 09:08] by Moderator
Re: Autobuild is triggered when shutting down an Eclipse application [message #1773913 is a reply to message #1773908] Fri, 06 October 2017 09:27 Go to previous messageGo to next message
According to https://bugs.eclipse.org/bugs/show_bug.cgi?id=75772, the "org.eclipse.osgi" will enter the STOPPING state after the Eclipse application has terminated. That means, the AutobuildJob may be executed during the process of closing the application before the Eclipse application has terminated.
Re: Autobuild is triggered when shutting down an Eclipse application [message #1773917 is a reply to message #1773913] Fri, 06 October 2017 09:40 Go to previous message
Thanks to the tips in https://bugs.eclipse.org/bugs/show_bug.cgi?id=75772, I can always reliably abort a build when the application is being closed using the following check:
			// Ignore if the application is closing
			if (Workbench.getInstance().isClosing()) {
				return;
[Updated on: Fri, 06 October 2017 09:41] by Moderator
Previous Topic:blank window under Javafx
Next Topic:Problem to open Eclipse
Current Time: Sun Jul 27 16:33:31 EDT 2025
Powered by FUDForum. Page generated in 0.04449 seconds
