Home » Modeling » TMF (Xtext) » Java 8 compatibility for Guice
Java 8 compatibility for Guice [message #1773893] Fri, 06 October 2017 04:21 Go to next message
Hello everbody,
i am facing the same problem as descripted in this issue (https://github.com/eclipse/xtext-core/issues/393) on github.
It looks like Guice 3 has compatibility problems when using Java 8.
Since xtext 2.12 is using Guice 3, I often get the following exception:
Toggle Spoiler
Is there a workaround for this problem or plans to move to Guice 4?
Thank you in advance.
Re: Java 8 compatibility for Guice [message #1773894 is a reply to message #1773893] Fri, 06 October 2017 04:23 Go to previous messageGo to next message
the workaround is not to make errors in your guice bindings ... ;)
Re: Java 8 compatibility for Guice [message #1774069 is a reply to message #1773894] Tue, 10 October 2017 03:43 Go to previous message
The problem was that we called the method "createInjectorAndDoEMFRegistration" in two different servlets to get the injector.
Previous Topic:Build triggered when opening file in language implemented by Xtext
Next Topic:Xtext Code Navigation
Current Time: Thu Jul 24 23:46:05 EDT 2025
Powered by FUDForum. Page generated in 0.04458 seconds
