Re: Movement commands through 4diac [message #1774846 is a reply to message #1774760] |
Fri, 20 October 2017 09:35   |
This is giving me a headache... So I tried to do exactly as you described, but that changed nothing. Then I tried to change the main() like this
int main(int argc, char *arg[]){
checkEndianess();
std::string rosdistro = "indigo";
if (rosdistro == (std::string)std::getenv("ROS_DISTRO")){
DEVLOG_INFO("path to forte.exe: %s \n", arg[0]);
ros::init(argc, arg, "ROS_Functionblocks_in_FORTE");
if(argc <= 1){ //! Default Value (localhost:61499)
createDev("localhost:61499");
but i got an error
"terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct null not valid"
and then I tried to just skip the if statement, because I really have ros indigo installed, but I got this error
"INFO: T#notime: path to forte.exe: /home/sofia/org.eclipse.4diac.forte/bin/posix/src/forte
[31m [1508502037.873067018]: ROS_MASTER_URI is not defined in the environment. Either type the following or (preferrably) add this to your ~/.bashrc file in order set up your local machine as a ROS master:
export ROS_MASTER_URI=http://localhost:11311
then, type 'roscore' in another shell to actually launch the master program.[0m"
even though I have edited my ~/.bashrc file, as I should have.
So now, after I red every similar error that was ever posted on the internet, I will try to install ros, gazebo etc to another computer to see if there is something wrong with my installation. Thank you for your help.
FUDForum. Page generated in 0.08388 seconds
