Home » Newcomers » Newcomers » Eclipse error when add new project(Eclipse error when add new project)
Eclipse error when add new project [message #1773795] Wed, 04 October 2017 13:48 Go to next message
Hi All,
I am trying to set new project in Eclipse and I have installed following the instructions and the installation worked fine but i am having an issue when i try to create new project and I try to download the metadata.
When I do it i have the following error "unable to open custom component selection dialog eclipse"
I checked java versions and eclipse installations are everything is fine.
Is there any workaround you can recommend in order to resolve this incident?
Thanks and Regards,
Eduardo
Re: Eclipse error when add new project [message #1773797 is a reply to message #1773795] Wed, 04 October 2017 14:20 Go to previous messageGo to next message
Next time, please add the images in an image format, and not as proprietary Microsoft format document. I picked the images and added them to this message to show what I mean.
You should also have told that this is a Force.com project, and not a plain Eclipse project. It is obviously off-topic here. You should go to a Force.com support forum instead.
index.php/fa/30894/0/
index.php/fa/30895/0/
  • Attachment: error1.png
    (Size: 95.20KB, Downloaded 1474 times)
  • Attachment: error2.png
    (Size: 112.75KB, Downloaded 1378 times)
[Updated on: Wed, 04 October 2017 14:22] by Moderator
Re: Eclipse error when add new project [message #1773915 is a reply to message #1773797] Fri, 06 October 2017 09:32 Go to previous messageGo to next message
I am sure this is a hassle. Did you try to erase the current IDE and install a new Eclipse IDE yet?
Seth
Re: Eclipse error when add new project [message #1774050 is a reply to message #1773915] Mon, 09 October 2017 15:18 Go to previous messageGo to next message
Hi Seth,
Thanks for your reply I have tried differents workarounds, my eclipse current version is 4.7.1 and kind rare since I can retreive the information for lighting and visualforce under my force.com project but when i try to retreive metadata i have the following error attached.
There are the logs:
WARN [2017-10-03 16:50:59,108] (ConnectionFactory.java:clearCache:217) - No cached connections
WARN [2017-10-03 16:50:59,119] (DescribeObjectRegistry.java:clearCache:660) - No cached describes
WARN [2017-10-03 16:50:59,122] (MetadataFactory.java:clearCache:125) - No cached metadata stubs
WARN [2017-10-03 17:21:18,428] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
LoginFault: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:21:18,443] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-03 17:21:18,451] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox': Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:21:18,482] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:22:10,041] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-03 17:22:10,097] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-03 17:22:10,102] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox': Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:22:10,147] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-03 17:24:33,875] (ComponentResource.java:loadFromFile:430) - File 'src/package.xml' does not exist
WARN [2017-10-04 09:21:09,766] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:23:25,581] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
at java.lang.String$CaseInsensitiveComparator.compare(Unknown Source)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt$1.compare(FileMetadataExt.java:37)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt$1.compare(FileMetadataExt.java:1)
at java.util.TimSort.binarySort(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt.sort(FileMetadataExt.java:418)
at com.salesforce.ide.core.remote.metadata.FileMetadataExt.getFilePropertiesMap(FileMetadataExt.java:322)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController$1.run(PackageManifestController.java:298)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:483)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:237)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:989)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateCache(PackageManifestController.java:295)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.loadAll(PackageManifestController.java:486)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateManifest(PackageManifestController.java:173)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.getEnabledCompTypeTreeNodes(PackageManifestController.java:439)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree$ManifestContentProvider.getElements(PackageManifestTree.java:690)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:995)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:701)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1340)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:341)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:901)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:618)
at org.eclipse.jface.viewers.AbstractTreeViewer.lambda$0(AbstractTreeViewer.java:814)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:792)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:595)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:763)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1527)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:771)
at org.eclipse.jface.viewers.AbstractTreeViewer.lambda$1(AbstractTreeViewer.java:1512)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1447)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:354)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1408)
at org.eclipse.jface.viewers.CheckboxTreeViewer.preservingSelection(CheckboxTreeViewer.java:403)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree$PackageManifestTreeViewer.preservingSelection(PackageManifestTree.java:417)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1506)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:286)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1685)
at com.salesforce.ide.ui.packagemanifest.PackageManifestTree.updateTree(PackageManifestTree.java:1693)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsComposite.initialize(ProjectCustomComponentsComposite.java:116)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsComposite.<init>(ProjectCustomComponentsComposite.java:72)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsDialog.createDialogArea(ProjectCustomComponentsDialog.java:59)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at com.salesforce.ide.ui.wizards.project.ProjectCustomComponentsDialog.create(ProjectCustomComponentsDialog.java:156)
at org.eclipse.jface.window.Window.open(Window.java:783)
at com.salesforce.ide.ui.wizards.project.ProjectProjectContentComposite$8.widgetDefaultSelected(ProjectProjectContentComposite.java:294)
at com.salesforce.ide.ui.wizards.project.ProjectProjectContentComposite$8.widgetSelected(ProjectProjectContentComposite.java:309)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:133)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
ERROR [2017-10-04 09:23:37,231] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
at com.salesforce.ide.core.internal.utils.PackageManifestDocumentUtils.getPackageNode(PackageManifestDocumentUtils.java:157)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.getComponentTypesFromCache(PackageManifestController.java:1002)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.createModel(PackageManifestController.java:827)
at com.salesforce.ide.ui.packagemanifest.PackageManifestController.updateManifest(PackageManifestController.java:174)
WARN [2017-10-04 09:23:39,269] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:23:39,307] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
at java.util.TimSort.countRunAndMakeAscending(Unknown Source)
ERROR [2017-10-04 09:23:40,532] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:24:17,604] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-04 09:24:17,606] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-04 09:24:17,608] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sanbox Backup': Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:24:17,629] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:25:23,943] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:27:20,145] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:27:47,809] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:34:30,215] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:35:56,749] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:37:12,879] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
WARN [2017-10-04 09:50:40,830] (BaseRetryAspect.java:isLoginExceptionRetryable:124) - Login evaluation deemed exception not retry-able:
WARN [2017-10-04 09:50:40,835] (BaseRetryAspect.java:isConnectionExceptionRetryable:159) - Connection evaluation deemed exception not retry-able:
WARN [2017-10-04 09:50:40,840] (ProjectController.java:getRemotePackageNames:862) - Unable to get project packages for project 'Sandbox Backup': Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:50:40,874] (ProjectOrganizationPage.java:prepareNextPage:263) - Unable to login: Invalid username, password, security token; or user locked out.
WARN [2017-10-04 09:53:10,078] (Utils.java:loadDocument:807) - Unable to load document: C:\Users\0124259\eclipse-workspace\.metadata\.plugins\com.salesforce.ide.core\packageCache.xml (The system cannot find the file specified)
ERROR [2017-10-04 09:54:35,931] (PackageManifestController.java:loadAll:502) - Unable to refresh file metadata
ERROR [2017-10-04 09:56:29,610] (ProjectProjectContentComposite.java:widgetDefaultSelected:296) - Unable to open custom component selection dialog
  • Attachment: ECLIPSE 1.png
    (Size: 95.20KB, Downloaded 163 times)
Re: Eclipse error when add new project [message #1774062 is a reply to message #1774050] Tue, 10 October 2017 00:32 Go to previous message
Likely there is a forum more specific for asking questions about whatever it is that "com.salesforce" provides. This is not something distributed from Eclipse itself, so it's unlikely anyone where can answer this. Perhaps https://developer.salesforce.com/forums/ForumsRSS
Previous Topic:Windows of the project editor
Next Topic:Pls help
Current Time: Sat Jul 26 23:42:04 EDT 2025
Powered by FUDForum. Page generated in 0.13233 seconds
