parse namespaced variable names [message #1773623] |
Sun, 01 October 2017 03:52  |
I am new to Xtext, and would really appreciate if any of you can help me fix the following problem.
I want to write a DSL that would be able to parse code like the following:
var m:a/b/c
var c:d/e/f
var m:h/i/j
def add(
int v1,
int v2)
let m:h/i/j = add(v1=m:a/b/c, v2=c:d/e/f)
The idea is in the "let" statement, the left side of the equation can only get all the vars already defined in the content assistance.
I have the following grammar:
grammar org.xtext.example.Calculator with org.eclipse.xtext.common.Terminals
generate calculatorDSL "..."
Model:
statements += Statement*;
Statement:
Variable | Func | Assignment;
Variable: 'var' name=PathId;
Func: 'def' name=ID '(' parameters += Parameter* ')';
Assignment: 'let' what = [Variable] '=' callee = [Func] '(' ')';
QualifiedName:ID ('/' ID)*;
enum PartitionType: m|c|t;
Partition: name=PartitionType ':';
Path: {Path} name=QualifiedName;
PathId: part=Partition path=Path ;
Parameter: type = ParameterType name = ID ;
ParameterType: elementType=ElementType (array ?='[' (length=INT)? ']')?;
ElementType: BasicType | EntityType;
BasicType: typeName = ('string' | 'int' | 'boolean');
EntityType: typeName = 'composite';
In the grammar, the Assignment rule tries to use the [Variable] to get all the vars defined, so that when ctrl+space is pressed it show them up. But instead, I got an error message in the "let" statement if I try the following:
var m:this/is/a/field
var c:this/is/a/constant
var m:this/is/the/result
def add(
int v1
int v2)
// all the lines above worked as expected
let m:this/is/the/result = add()
In the above DSL code, in the let statement, an error shows "mismatched input 'm' expecting RULE_ID".
I have been trying to find solutions for hours but got nowhere. Can anyone offer some insight on how to fix it?
Thanks.
Re: parse namespaced variable names [message #1773675 is a reply to message #1773670] |
Mon, 02 October 2017 12:50   |
Chris,
Thanks for the reply, but I am not sure I fully understand your suggestion, or if the suggestion fits this use case.
First, I tested with using ^ to escape as suggested by the blog, it did not work as the blog suggests. Secondly, if there are slashes "/" in the var names, the content assistance does not pick them up.
I guess my question is more or less distilled to the following:
1. In my DSL, the variables are not just ID's, rather they are composed of two parts:
[namespace]:[path], where namespace is from an enum, and path contains "/".
2. When a prior defined var such as "m:a/b/c" is cross referenced later on in the DSL, I'd like the content assistance to bring up these vars smartly. Namely: when I type "m:" and ctrl-space, it would show "m:a/b/c" and "m:e/f/g" and so on. If I type "m:a" it would only show "m:a/b/c".
Can you share some insights on how to do this? Maybe with a minimal grammar?
Thanks in advance for your teaching. BTW, I have been reading your blogs and posts about Xtext, and learned a lot. Appreciate what you do for the community!
Re: parse namespaced variable names [message #1773751 is a reply to message #1773689] |
Wed, 04 October 2017 02:39   |
Chris,
Thanks very much for your patience, and help. I am new to the technology and your suggestions are valuable and cannot be overstated.
I was limited in my thinking to hope it can be done purely by tweaking the grammar. It hadn't occurred to me I need code up the providers. Now I kinda got it work to an extent. But I now have more questions.
1. I couldn't get the first name provider work. Particularly, I got a compiler error in the following line complaining it cannot find 'path' and 'part' for variable 'v'.
QualifiedName.create(v.name.part.name.name().toLowerCase+":"+v.name.path.name)
2. I found that QualifiedName is kinda special --- I tried to use another way such as "MyQualifiedName" in the grammar, together adjusting the code, but got problems --- "MyQualifiedName cannot be resolved to a type." Did I miss anything here?
Path: {Path} name = MyQualifiedName; //QualifiedName;
MyQualifiedName:ValidID ('/' ValidID)*;
class CalcGraphDSLNameProvider extends DefaultDeclarativeQualifiedNameProvider {
def MyQualifiedName qualifiedName(Variable v) {
MyQualifiedName.create(NodeModelUtils.findNodesForFeature(v, CalcGraphDSLPackage.Literals.VARIABLE__NAME).head.text.trim)
3. More seriously, the hover over behavior is broken. Now if I hover over a variable, in the tool tip window, it shows just "Variable" without the variable name. If I use [Variable|STRING] rule, I can get the right behavior at hovering over i.e. "Variable m:a/b/c". of course, using STRING does not give me the right content assistance behavior as we discussed. Any insight on how I can fix it?
One thing I am guessing is that with the CompleteVarName rule, the variables in the "let" statement don't match up with the variables in the "var" statement. But why the content assistance works then? I am puzzled.
Thanks again.
Re: parse namespaced variable names [message #1773791 is a reply to message #1773784] |
Wed, 04 October 2017 12:18  |
class MyDslNameProvider extends DefaultDeclarativeQualifiedNameProvider {
def QualifiedName qualifiedName(Variable v) {
=> compiles fine. no errors.
references work.
no switch you can name thing thing "Whatever" in the grammar, the nameprovider still returns QualifiedName
inherit from DefaultDeclarativeQualifiedNameProvider or IQualifiedNameProvider interface but no MyQualifiedName or Whatever.
for hover edit label provider e.g
class MyDslLabelProvider extends DefaultEObjectLabelProvider {
@Inject
new(AdapterFactoryLabelProvider delegate) {
super(delegate);
@Inject
IQualifiedNameProvider qnp;
def text(Variable v) {
qnp.getFullyQualifiedName(v).toString
FUDForum. Page generated in 0.52868 seconds
