Unable to start Eclipse Rdz Environment [message #1773627] |
Sun, 01 October 2017 15:09 |
Alon Amiramov Messages: 1 Registered: October 2017 |
I work with Eclipse When I try to open Eclipse I have the following error. It is chinese for me. Could you tell me what to do ? Thanks in advance. Here is the log file content:
!ENTRY com.ibm.rational.llc.ide.core 4 0 2017-10-01 17:50:32.253
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in com.ibm.rational.llc.internal.core.CoverageCorePlugin.stop() of bundle com.ibm.rational.llc.ide.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(Unknown Source)
at org.eclipse.osgi.container.Module.doStop(Unknown Source)
at org.eclipse.osgi.container.Module.stop(Unknown Source)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(Unknown Source)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(Unknown Source)
at org.eclipse.osgi.container.SystemModule.stopWorker(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(Unknown Source)
at org.eclipse.osgi.container.SystemModule.stop(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: org.eclipse.core.resources.IResourceChangeListener
at com.ibm.rational.llc.internal.core.CoverageCorePlugin.stop(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(Unknown Source)
at java.security.AccessController.doPrivileged(Unknown Source)
... 14 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (1598).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Unknown Source)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.equinox.launcher.Main.basicRun(Unknown Source)
at org.eclipse.equinox.launcher.Main.run(Unknown Source)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(Unknown Source)
at org.eclipse.osgi.container.Module.doStart(Unknown Source)
at org.eclipse.osgi.container.Module.start(Unknown Source)
at org.eclipse.osgi.framework.util.SecureAction.start(Unknown Source)
... 23 more
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/HostConnectProjectFiles/SYSA.hce' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(Unknown Source)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(Unknown Source)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(Unknown Source)
at org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDelta(Unknown Source)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(Unknown Source)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(Unknown Source)
at org.eclipse.core.internal.watson.ElementTree.immutable(Unknown Source)
at org.eclipse.core.internal.resources.SaveManager.restore(Unknown Source)
at org.eclipse.core.internal.resources.SaveManager.startup(Unknown Source)
at org.eclipse.core.internal.resources.Workspace.startup(Unknown Source)
at org.eclipse.core.internal.resources.Workspace.open(Unknown Source)
at org.eclipse.core.resources.ResourcesPlugin.start(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(Unknown Source)
... 30 more
Root exception:
... 23 more
... 30 more
FUDForum. Page generated in 0.29379 seconds
