Extend existing diagram [message #1771656] |
Tue, 29 August 2017 03:52  |
I want to extend an existing Papyrus diagram (e.g. the statemachine diagram). I want to add new elements in the palette, new properties in object...
Is there a best way, and documeted, to extend the statemachine diagram, and keep usin the papyrus editor?
I eard about a forum last May, but I didn't found the link.
I'm using Papyrus 3.0.0
Best regards
[Updated on: Tue, 29 August 2017 03:53] by Moderator
Re: Extend existing diagram [message #1774363 is a reply to message #1774285] |
Fri, 13 October 2017 06:05  |
Hi Ismael,
Ismael Soulama wrote on Thu, 12 October 2017 13:24
Is there something missing?
sorry, but I can't know if something is missing by just seeing a piece of code.
Some points to take in account:
- Are you sure your profile is being registered? You should be able to apply it from "Apply registered profile".
- If you want to apply the profile directly to your model when you create it, you must customize your creationCommandClass, as in the library example.
https://github.com/bmaggi/library-training/blob/master/org.eclipse.papyrus.training.library.architecture/src/org/eclipse/papyrus/training/library/architecture/TrainingLibraryModelCreationCommand.java
- If your stereotypes aren't applied on the element when you drag and drop it from your customized palette, review your *.elementtypesconfigurations files.
https://github.com/bmaggi/library-training/blob/master/org.eclipse.papyrus.training.library.newchild/resources/extLibrary.elementtypesconfigurations
https://github.com/bmaggi/library-training/blob/master/org.eclipse.papyrus.training.library.palette/resources/extlibrarydi.elementtypesconfigurations
To know if the elements are being rightly referenced, deploy the plugin and then open the palette model and the element type set models (*.elementtypesconfigurations files) and show the Properties tab. you should be able to navigate through the whole models. If some reference is wrong, you will get an error, so you will know what reference is wrong.
Regards.
[Updated on: Fri, 13 October 2017 06:38] by Moderator
FUDForum. Page generated in 0.04200 seconds
