Home » Eclipse Projects » EGit / JGit » Authentication failure - No password provided - although password was entered
Authentication failure - No password provided - although password was entered [message #1773389] |
Wed, 27 September 2017 04:30  |
I have a problem with EGit/jGit even after installing the latest version from the nightly build repository. We are connecting to a locally hosted TFS GIT instance using https. Git Windows command line client as well as GUI front ends like SourceTree or the Github Desktop work fine. EGit does prompt for credentials but then fails with a 'No passwaord provided' authentication error. Here is a sample stacktrace:
!ENTRY org.eclipse.egit.core 4 0 2017-09-27 15:33:03.493
!MESSAGE An exception occurred during push on URI https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS: https://tfs.synergy.net.au/tfs/Synergy/
WBU/_git/STARS: null
!STACK 0
org.eclipse.jgit.api.errors.TransportException: https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS: null
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:180)
at org.eclipse.egit.core.op.PushOperation.run(PushOperation.java:215)
at org.eclipse.egit.ui.internal.push.PushJob.performJob(PushJob.java:84)
at org.eclipse.egit.ui.internal.jobs.RepositoryJob.run(RepositoryJob.java:57)
Caused by: org.eclipse.jgit.errors.TransportException: https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS: null
at org.eclipse.jgit.transport.BasePackPushConnection.doPush(BasePackPushConnection.java:238)
at org.eclipse.jgit.transport.TransportHttp$SmartHttpPushConnection.doPush(TransportHttp.java:1119)
at org.eclipse.jgit.transport.BasePackPushConnection.push(BasePackPushConnection.java:170)
at org.eclipse.jgit.transport.PushProcess.execute(PushProcess.java:172)
at org.eclipse.jgit.transport.Transport.push(Transport.java:1310)
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:169)
... 4 more
Caused by: java.io.IOException
at org.eclipse.jgit.transport.HttpAuthMethod$Negotiate.configureRequest(HttpAuthMethod.java:560)
at org.eclipse.jgit.transport.TransportHttp.httpOpen(TransportHttp.java:861)
at org.eclipse.jgit.transport.TransportHttp$Service.openStream(TransportHttp.java:1150)
at org.eclipse.jgit.transport.TransportHttp$Service.sendRequest(TransportHttp.java:1187)
at org.eclipse.jgit.transport.TransportHttp$MultiRequestService.execute(TransportHttp.java:1415)
at org.eclipse.jgit.transport.TransportHttp$Service$HttpExecuteStream.read(TransportHttp.java:1345)
at org.eclipse.jgit.util.io.UnionInputStream.read(UnionInputStream.java:145)
at java.io.FilterInputStream.read(FilterInputStream.java:133)
at org.eclipse.jgit.util.io.TimeoutInputStream.read(TimeoutInputStream.java:112)
at org.eclipse.jgit.util.IO.readFully(IO.java:247)
at org.eclipse.jgit.transport.PacketLineIn.readLength(PacketLineIn.java:225)
at org.eclipse.jgit.transport.SideBandInputStream.needDataPacket(SideBandInputStream.java:154)
at org.eclipse.jgit.transport.SideBandInputStream.read(SideBandInputStream.java:136)
at org.eclipse.jgit.transport.PacketLineIn.readString(PacketLineIn.java:155)
at org.eclipse.jgit.transport.BasePackPushConnection.readStringLongTimeout(BasePackPushConnection.java:437)
at org.eclipse.jgit.transport.BasePackPushConnection.readStatusReport(BasePackPushConnection.java:369)
at org.eclipse.jgit.transport.BasePackPushConnection.doPush(BasePackPushConnection.java:221)
... 9 more
Caused by: GSSException: No valid credentials provided (Mechanism level: No valid credentials provided (Mechanism level: Attempt to obtain new I
NITIATE credentials failed! (null)))
at sun.security.jgss.spnego.SpNegoContext.initSecContext(SpNegoContext.java:454)
at sun.security.jgss.GSSContextImpl.initSecContext(GSSContextImpl.java:248)
at sun.security.jgss.GSSContextImpl.initSecContext(GSSContextImpl.java:179)
at org.eclipse.jgit.transport.HttpAuthMethod$Negotiate.configureRequest(HttpAuthMethod.java:554)
... 27 more
Caused by: GSSException: No valid credentials provided (Mechanism level: Attempt to obtain new INITIATE credentials failed! (null))
at sun.security.jgss.krb5.Krb5InitCredential.getTgt(Krb5InitCredential.java:343)
at sun.security.jgss.krb5.Krb5InitCredential.getInstance(Krb5InitCredential.java:145)
at sun.security.jgss.krb5.Krb5MechFactory.getCredentialElement(Krb5MechFactory.java:122)
at sun.security.jgss.krb5.Krb5MechFactory.getMechanismContext(Krb5MechFactory.java:187)
at sun.security.jgss.GSSManagerImpl.getMechanismContext(GSSManagerImpl.java:224)
at sun.security.jgss.GSSContextImpl.initSecContext(GSSContextImpl.java:212)
at sun.security.jgss.spnego.SpNegoContext.GSS_initSecContext(SpNegoContext.java:882)
at sun.security.jgss.spnego.SpNegoContext.initSecContext(SpNegoContext.java:317)
... 30 more
Caused by: javax.security.auth.login.LoginException: No password provided
at com.sun.security.auth.module.Krb5LoginModule.promptForPass(Krb5LoginModule.java:919)
at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:760)
at com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:617)
at javax.security.auth.login.LoginContext.invoke(LoginContext.java:755)
at javax.security.auth.login.LoginContext.access$000(LoginContext.java:195)
at javax.security.auth.login.LoginContext$4.run(LoginContext.java:682)
at javax.security.auth.login.LoginContext$4.run(LoginContext.java:680)
at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
at javax.security.auth.login.LoginContext.login(LoginContext.java:587)
at sun.security.jgss.GSSUtil.login(GSSUtil.java:258)
at sun.security.jgss.krb5.Krb5Util.getTicket(Krb5Util.java:158)
at sun.security.jgss.krb5.Krb5InitCredential$1.run(Krb5InitCredential.java:335)
at sun.security.jgss.krb5.Krb5InitCredential$1.run(Krb5InitCredential.java:331)
at sun.security.jgss.krb5.Krb5InitCredential.getTgt(Krb5InitCredential.java:330)
... 38 more
Any suggestions what might be going wrong?
Re: Authentication failure - No password provided - although password was entered [message #1776465 is a reply to message #1776442] |
Thu, 16 November 2017 11:04   |
Great. What exactly do you have now? A JGit-only workspace, or a combined EGit/JGit workspace? If you did the automated Oomph setup, you'd have a combined workspace, and things will be simpler.
If you have a combined EGit/JGit workspace, you could just download the change from Gerrit and start a runtime workbench, then try cloning a repository from your TFS.
Downloading the change from Gerrit would be the command
git fetch https://git.eclipse.org/r/jgit/jgit refs/changes/71/111671/3 && git checkout FETCH_HEAD
or in Eclipse "Fetch from Gerrit..." (context menu on the JGit clone in the repositories view) and then enter the change number 111671, hit ctrl-space, then select the latest patch set (number 3). Eclipse will check out the change, Eclipse will re-build, and then you can start a runtime workbench and try cloning from TFS in there.
If you have a JGit-only workspace, chances are that this won't work because the JGit target platform has no Eclipse components. So you'd download the change from Gerrit, and then build JGit with maven on the command-line. That will produce a p2 update site that you can use to install that JGit in another Eclipse. Once installed there, you'd try cloning from your TFS server.
Building on the command-line needs maven, so you'd have to have that. The steps are described in the Contributor's Guide; basically it's
mvn clean install
mvn -f org.eclipse.jgit.packaging/pom.xml clean install
That should produce a p2 repository at <jgit-clone-dir>/org.eclipse.jgit.packaging/org.eclipse.jgit.repository/target/repository/ that could be used to install that JGit version in an Eclipse.
Re: Authentication failure - No password provided - although password was entered [message #1776664 is a reply to message #1776628] |
Mon, 20 November 2017 02:25   |
Manuel Mall wrote on Sun, 19 November 2017 05:08Good news - it works!
Great! So at least we did understand more or less correctly what was going on.
Quote:Ended up installing full eGit/jGit environment using Oomph and added your changes as suggested above. Then successfully cloned our TFS Git repo through Eclipse and pushed a change to TFS through Eclipse as well. Both operations don't work without the patch. Tracing the HTTP headers confirmed that jGit ends up falling back to HTTP Basic Authentication on the POST requests.
Thanks a lot for going to all that trouble to verify this. We really should have a simpler way how people could test such not-yet-merged changes.
Quote:GETs still use NTLM though. This could lead to some confusion as it means for Git operations involving GETs the Windows desktop credentials are used while for operations using POSTs the credentials configured in Eclipse are used. I guess it would be preferable to be consistent - all Git operations to either use NTLM or Basic Authentication - not a mix. Especially because in a TFS environment using the Active Directory (desktop) credentials with HTTP Basic Authentication to TFS does not work! You need to create a Personal Access Token in TFS as described for example in https://docs.microsoft.com/en-us/vsts/accounts/use-personal-access-tokens-to-authenticate and then its use in the HTTP Authorization header is described in https://docs.microsoft.com/en-us/vsts/integrate/get-started/rest/basics. In Eclipse this means you must enter an empty Username and the Personal Access Token as the Password.
We should add that info to the EGit documentation.
I'm afraid we can't do anything about that NTLM. It's entirely handled by Java's HttpUrlConnection, which does use it on the GET but apparently not on the POST. As I wrote on bugzilla, it's also hard to see how it could be used on POST, since the Java libraries do not have the POST data, which would need to be re-sent.
Java does have a http.auth.preference system property that a user could set to disable NTLM, but it's a bit restrictive in that it allows to specify only one authentication scheme. AFAIK there's no way to define a sequence of schemes, such as Negotiate->Digest->Basic.
Microsoft's own specification of NTLM is interesting. I quote from v20170915, section 5.1, "Security considerations for implementers":
Quote:Therefore, applications are generally advised not to use NTLM. (Emphasis added.)
Also, there's RFC 4559, which says:
Quote:It is not always possible to mutually authenticate the server before the HTTP operation. POST methods are in this category.
[On POST requests] the authentication should be complete between the client and server before sending the user data.
As far as I see, Java doesn't give us a way to implement this latter bit. We have to send the data at least once to get the initial 401 response. Unless I'm missing something.
Re: Authentication failure - No password provided - although password was entered [message #1776821 is a reply to message #1776797] |
Tue, 21 November 2017 19:14   |
I played around with this a bit more (what a time sink...) and decided that Kerberos and Windows Java clients don't work nicely together. But then I wrote myself a little test program:
package au.net.synergy.wts.security.tools;
import java.io.InputStream;
import java.net.HttpURLConnection;
import java.net.URL;
import sun.util.logging.PlatformLogger;
public class GitTest {
public static void main(final String[] args) throws Exception {
System.setProperty("javax.net.ssl.trustStore", "NONE");
System.setProperty("javax.net.ssl.trustStoreType", "Windows-ROOT");
// System.setProperty("javax.net.debug", "all");
System.setProperty("java.security.krb5.realm", "CORP.INT");
System.setProperty("java.security.krb5.kdc", "corp.int");
System.setProperty("sun.security.krb5.debug", "true");
// System.setProperty("http.auth.preference", "SPNEGO");
sun.util.logging.PlatformLogger .getLogger("sun.net.www.protocol.http.HttpURLConnection") .setLevel(PlatformLogger.Level.ALL);
final InputStream is = new URL("https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack").openStream();
final byte[] ba = new byte[1024*1024];
final int len = is.read(ba);
is.close();
final URL url = new URL("https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack");
final HttpURLConnection conn = (HttpURLConnection)url.openConnection();
conn.setRequestMethod("POST");
conn.setRequestProperty( "Content-Type", "application/x-git-receive-pack-request");
conn.setDoOutput(true);
conn.getOutputStream().write(ba, len, 0);
conn.getInputStream().read(ba);
Nothing fancy, just emulating what jGit does, first a GET to TFS and then a POST. Interesting observation, in my test the Java HttpURLConnection does fall back to NTLM on the POST. Question is why doesn't it do it in the jGit case? Here is the console output of this program. It shows the same exception as jGit with respect to Kerberos but then falls back to NTLM:
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.http.HttpURLConnection plainConnect0
FINEST: ProxySelector Request for https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.https.HttpsClient New
FINEST: Looking for HttpClient for URL https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack and proxy value of DIRECT
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.https.HttpsClient <init>
FINEST: Creating new HttpsClient with url:https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack and proxy:DIRECT with connect timeout:-1
FINEST: Proxy used: DIRECT
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.http.HttpURLConnection writeRequests
FINE: sun.net.www.MessageHeader@20e2cbe05 pairs: {GET /tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack HTTP/1.1: null}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}
Nov 22, 2017 8:03:50 AM sun.net.www.http.HttpClient logFinest
FINEST: KeepAlive stream used: https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.http.HttpURLConnection getInputStream0
FINE: sun.net.www.MessageHeader@68be2bc221 pairs: {null: HTTP/1.1 401 Unauthorized}{Content-Type: text/html; charset=utf-8}{Server: Microsoft-IIS/8.5}{X-TFS-ProcessId: f968ad58-674d-4bdd-9b09-96cd9ba9a64c}{ActivityId: 1ba73d8d-3e1e-471c-9e6c-d8a73a5d3f3b}{X-TFS-Session: 1ba73d8d-3e1e-471c-9e6c-d8a73a5d3f3b}{X-VSS-E2EID: 1ba73d8d-3e1e-471c-9e6c-d8a73a5d3f3b}{X-FRAME-OPTIONS: SAMEORIGIN}{X-TFS-SoapException: %3c%3fxml+version%3d%221.0%22+encoding%3d%22utf-8%22%3f%3e%3csoap%3aEnvelope+xmlns%3asoap%3d%22http%3a%2f%2fwww.w3.org%2f2003%2f05%2fsoap-envelope%22%3e%3csoap%3aBody%3e%3csoap%3aFault%3e%3csoap%3aCode%3e%3csoap%3aValue%3esoap%3aReceiver%3c%2fsoap%3aValue%3e%3csoap%3aSubcode%3e%3csoap%3aValue%3eUnauthorizedRequestException%3c%2fsoap%3aValue%3e%3c%2fsoap%3aSubcode%3e%3c%2fsoap%3aCode%3e%3csoap%3aReason%3e%3csoap%3aText+xml%3alang%3d%22en%22%3eTF400813%3a+Resource+not+available+for+anonymous+access.+Client+authentication+required.%3c%2fsoap%3aText%3e%3c%2fsoap%3aReason%3e%3c%2fsoap%3aFault%3e%3c%2fsoap%3aBody%3e%3c%2fsoap%3aEnvelope%3e}{X-TFS-ServiceError: TF400813%3a+Resource+not+available+for+anonymous+access.+Client+authentication+required.}{WWW-Authenticate: Bearer}{WWW-Authenticate: Basic realm="https://tfs.synergy.net.au/tfs"}{WWW-Authenticate: Negotiate}{WWW-Authenticate: NTLM}{X-Powered-By: ASP.NET}{P3P: CP="CAO DSP COR ADMa DEV CONo TELo CUR PSA PSD TAI IVDo OUR SAMi BUS DEM NAV STA UNI COM INT PHY ONL FIN PUR LOC CNT"}{Lfs-Authenticate: NTLM}{X-Content-Type-Options: nosniff}{Date: Wed, 22 Nov 2017 00:03:51 GMT}{Content-Length: 20150}{Set-Cookie: BIGipServerPool_TFS=2315326474.36895.0000; path=/; Httponly; Secure}
Java config name: null
Native config name: C:\WINDOWS\krb5.ini
>>>KinitOptions cache name is C:\Users\emmall\krb5cc_emmall
>>>DEBUG <CCacheInputStream> client principal is emmall@CORP.INT
>>>DEBUG <CCacheInputStream> server principal is krbtgt/CORP.INT@CORP.INT
>>>DEBUG <CCacheInputStream> key type: 17
>>>DEBUG <CCacheInputStream> auth time: Tue Nov 21 13:08:35 AWST 2017
>>>DEBUG <CCacheInputStream> start time: Tue Nov 21 13:08:35 AWST 2017
>>>DEBUG <CCacheInputStream> end time: Tue Nov 21 23:08:35 AWST 2017
>>>DEBUG <CCacheInputStream> renew_till time: null
>>> CCacheInputStream: readFlags() INITIAL; PRE_AUTH;
Host address is /10.52.68.19
Host address is /fe80:0:0:0:81bd:8d6b:88d8:88eb
>>> KrbCreds found the default ticket granting ticket in credential cache.
>>> Obtained TGT from LSA: Credentials:
client=emmall@CORP.INT
server=krbtgt/CORP.INT@CORP.INT
authTime=20171121050835Z
startTime=20171121050835Z
endTime=20171121150835Z
renewTill=null
flags=INITIAL;PRE-AUTHENT
EType (skey)=17
(tkt key)=18
Negotiate support not initiated, will fallback to other scheme if allowed. Reason:
GSSException: No valid credentials provided (Mechanism level: No valid credentials provided (Mechanism level: Attempt to obtain new INITIATE credentials failed! (null)))
at sun.security.jgss.spnego.SpNegoContext.initSecContext(Unknown Source)
at sun.security.jgss.GSSContextImpl.initSecContext(Unknown Source)
at sun.net.www.protocol.http.spnego.NegotiatorImpl.init(Unknown Source)
at sun.net.www.protocol.http.spnego.NegotiatorImpl.<init>(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.net.www.protocol.http.Negotiator.getNegotiator(Unknown Source)
at sun.net.www.protocol.http.NegotiateAuthentication.isSupportedImpl(Unknown Source)
at sun.net.www.protocol.http.NegotiateAuthentication.isSupported(Unknown Source)
at sun.net.www.protocol.http.AuthenticationHeader.parse(Unknown Source)
at sun.net.www.protocol.http.AuthenticationHeader.<init>(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
at java.net.URL.openStream(Unknown Source)
at au.net.synergy.wts.security.tools.GitTest.main(GitTest.java:21)
at sun.security.jgss.krb5.Krb5InitCredential.getTgt(Unknown Source)
at sun.security.jgss.krb5.Krb5InitCredential.getInstance(Unknown Source)
at sun.security.jgss.krb5.Krb5MechFactory.getCredentialElement(Unknown Source)
at sun.security.jgss.krb5.Krb5MechFactory.getMechanismContext(Unknown Source)
at sun.security.jgss.GSSManagerImpl.getMechanismContext(Unknown Source)
at sun.security.jgss.spnego.SpNegoContext.GSS_initSecContext(Unknown Source)
... 20 more
at com.sun.security.auth.module.Krb5LoginModule.promptForPass(Unknown Source)
at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Unknown Source)
at com.sun.security.auth.module.Krb5LoginModule.login(Unknown Source)
at javax.security.auth.login.LoginContext.invoke(Unknown Source)
at javax.security.auth.login.LoginContext.access$000(Unknown Source)
at javax.security.auth.login.LoginContext$4.run(Unknown Source)
at javax.security.auth.login.LoginContext.invokePriv(Unknown Source)
at javax.security.auth.login.LoginContext.login(Unknown Source)
at sun.security.jgss.GSSUtil.login(Unknown Source)
at sun.security.jgss.krb5.Krb5Util.getTicket(Unknown Source)
at sun.security.jgss.krb5.Krb5InitCredential$1.run(Unknown Source)
... 28 more
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.http.Negotiator finest
FINEST: NegotiateAuthentication: java.lang.reflect.InvocationTargetException
FINEST: NegotiateAuthentication: java.io.IOException: Negotiate support not initiated
Nov 22, 2017 8:03:50 AM sun.net.www.protocol.http.HttpURLConnection getServerAuthentication
FINEST: Trying Transparent NTLM authentication
FINER: Server Authentication for AuthenticationHeader: prefer NTLM returned sun.net.www.protocol.http.ntlm.NTLMAuthentication@39aeed2f
FINE: sun.net.www.MessageHeader@20e2cbe06 pairs: {GET /tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack HTTP/1.1: null}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}{Authorization: NTLM TlRMTVNTUAABAAAAB7IIogQABAAwAAAACAAIACgAAAAGAbEdAAAAD1NXUzMyOTUzQ09SUA==}
FINE: sun.net.www.MessageHeader@68be2bc27 pairs: {null: HTTP/1.1 401 Unauthorized}{Content-Type: text/html; charset=us-ascii}{Server: Microsoft-HTTPAPI/2.0}{WWW-Authenticate: NTLM TlRMTVNTUAACAAAACAAIADgAAAAFgomiw9AhAzO1UlEAAAAAAAAAAIYAhgBAAAAABgOAJQAAAA9DAE8AUgBQAAIACABDAE8AUgBQAAEAFABQAEQAQwBQAFYAVABGAFMAMAAyAAQAEABjAG8AcgBwAC4AaQBuAHQAAwAmAFAARABDAFAAVgBUAEYAUwAwADIALgBjAG8AcgBwAC4AaQBuAHQABQAQAGMAbwByAHAALgBpAG4AdAAHAAgAWzPpYCVj0wEAAAAA}{Date: Wed, 22 Nov 2017 00:03:51 GMT}{Content-Length: 341}{Set-Cookie: BIGipServerPool_TFS=2315326474.36895.0000; path=/; Httponly; Secure}
FINE: sun.net.www.MessageHeader@20e2cbe06 pairs: {GET /tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack HTTP/1.1: null}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}{Authorization: NTLM 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}
Nov 22, 2017 8:03:51 AM sun.net.www.http.HttpClient logFinest
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.http.HttpURLConnection getInputStream0
FINE: sun.net.www.MessageHeader@4678c73018 pairs: {null: HTTP/1.1 200 OK}{Cache-Control: private}{Content-Type: application/x-git-receive-pack-advertisement}{Server: Microsoft-IIS/8.5}{X-TFS-ProcessId: f968ad58-674d-4bdd-9b09-96cd9ba9a64c}{ActivityId: 1ba73d37-3e1e-471c-9e6c-d8a73a5d3f3b}{X-TFS-Session: 1ba73d37-3e1e-471c-9e6c-d8a73a5d3f3b}{X-VSS-E2EID: 1ba73d37-3e1e-471c-9e6c-d8a73a5d3f3b}{X-FRAME-OPTIONS: SAMEORIGIN}{X-VSS-UserData: 8857810f-8109-444e-b448-37cbe4b6de34:emmall}{X-AspNet-Version: 4.0.30319}{Persistent-Auth: true}{X-Powered-By: ASP.NET}{P3P: CP="CAO DSP COR ADMa DEV CONo TELo CUR PSA PSD TAI IVDo OUR SAMi BUS DEM NAV STA UNI COM INT PHY ONL FIN PUR LOC CNT"}{Lfs-Authenticate: NTLM}{X-Content-Type-Options: nosniff}{Date: Wed, 22 Nov 2017 00:03:51 GMT}{Content-Length: 303878}
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.http.HttpURLConnection plainConnect0
FINEST: ProxySelector Request for https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.https.HttpsClient New
FINEST: Looking for HttpClient for URL https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack and proxy value of DIRECT
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.https.HttpsClient <init>
FINEST: Creating new HttpsClient with url:https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack and proxy:DIRECT with connect timeout:-1
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.http.HttpURLConnection writeRequests
FINE: sun.net.www.MessageHeader@29ee9faa7 pairs: {POST /tfs/Synergy/WBU/_git/STARS/git-receive-pack HTTP/1.1: null}{Content-Type: application/x-git-receive-pack-request}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}{Content-Length: 0}
FINEST: KeepAlive stream used: https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack
FINE: sun.net.www.MessageHeader@c03820321 pairs: {null: HTTP/1.1 401 Unauthorized}{Content-Type: text/html; charset=utf-8}{Server: Microsoft-IIS/8.5}{X-TFS-ProcessId: f968ad58-674d-4bdd-9b09-96cd9ba9a64c}{ActivityId: 1ba73d2f-3e1e-471c-9e6c-d8a73a5d3f3b}{X-TFS-Session: 1ba73d2f-3e1e-471c-9e6c-d8a73a5d3f3b}{X-VSS-E2EID: 1ba73d2f-3e1e-471c-9e6c-d8a73a5d3f3b}{X-FRAME-OPTIONS: SAMEORIGIN}{X-TFS-SoapException: %3c%3fxml+version%3d%221.0%22+encoding%3d%22utf-8%22%3f%3e%3csoap%3aEnvelope+xmlns%3asoap%3d%22http%3a%2f%2fwww.w3.org%2f2003%2f05%2fsoap-envelope%22%3e%3csoap%3aBody%3e%3csoap%3aFault%3e%3csoap%3aCode%3e%3csoap%3aValue%3esoap%3aReceiver%3c%2fsoap%3aValue%3e%3csoap%3aSubcode%3e%3csoap%3aValue%3eUnauthorizedRequestException%3c%2fsoap%3aValue%3e%3c%2fsoap%3aSubcode%3e%3c%2fsoap%3aCode%3e%3csoap%3aReason%3e%3csoap%3aText+xml%3alang%3d%22en%22%3eTF400813%3a+Resource+not+available+for+anonymous+access.+Client+authentication+required.%3c%2fsoap%3aText%3e%3c%2fsoap%3aReason%3e%3c%2fsoap%3aFault%3e%3c%2fsoap%3aBody%3e%3c%2fsoap%3aEnvelope%3e}{X-TFS-ServiceError: TF400813%3a+Resource+not+available+for+anonymous+access.+Client+authentication+required.}{WWW-Authenticate: Bearer}{WWW-Authenticate: Basic realm="https://tfs.synergy.net.au/tfs"}{WWW-Authenticate: Negotiate}{WWW-Authenticate: NTLM}{X-Powered-By: ASP.NET}{P3P: CP="CAO DSP COR ADMa DEV CONo TELo CUR PSA PSD TAI IVDo OUR SAMi BUS DEM NAV STA UNI COM INT PHY ONL FIN PUR LOC CNT"}{Lfs-Authenticate: NTLM}{X-Content-Type-Options: nosniff}{Date: Wed, 22 Nov 2017 00:03:51 GMT}{Content-Length: 20126}{Set-Cookie: BIGipServerPool_TFS=2315326474.36895.0000; path=/; Httponly; Secure}
Nov 22, 2017 8:03:51 AM sun.net.www.protocol.http.HttpURLConnection getServerAuthentication
FINEST: KeepAlive stream retrieved from the cache, sun.net.www.protocol.https.HttpsClient(https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/info/refs?service=git-receive-pack)
FINE: sun.net.www.MessageHeader@29ee9faa8 pairs: {POST /tfs/Synergy/WBU/_git/STARS/git-receive-pack HTTP/1.1: null}{Content-Type: application/x-git-receive-pack-request}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}{Content-Length: 0}{Authorization: NTLM TlRMTVNTUAABAAAAB7IIogQABAAwAAAACAAIACgAAAAGAbEdAAAAD1NXUzMyOTUzQ09SUA==}
FINE: sun.net.www.MessageHeader@c0382036 pairs: {null: HTTP/1.1 401 Unauthorized}{Content-Type: text/html; charset=us-ascii}{Server: Microsoft-HTTPAPI/2.0}{WWW-Authenticate: NTLM TlRMTVNTUAACAAAACAAIADgAAAAFgomioeQ0kk+gECcAAAAAAAAAAIYAhgBAAAAABgOAJQAAAA9DAE8AUgBQAAIACABDAE8AUgBQAAEAFABQAEQAQwBQAFYAVABGAFMAMAAyAAQAEABjAG8AcgBwAC4AaQBuAHQAAwAmAFAARABDAFAAVgBUAEYAUwAwADIALgBjAG8AcgBwAC4AaQBuAHQABQAQAGMAbwByAHAALgBpAG4AdAAHAAgA06r+YCVj0wEAAAAA}{Date: Wed, 22 Nov 2017 00:03:51 GMT}{Content-Length: 341}
FINE: sun.net.www.MessageHeader@29ee9faa8 pairs: {POST /tfs/Synergy/WBU/_git/STARS/git-receive-pack HTTP/1.1: null}{Content-Type: application/x-git-receive-pack-request}{User-Agent: Java/1.8.0_144}{Host: tfs.synergy.net.au}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}{Content-Length: 0}{Authorization: NTLM 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}
FINE: sun.net.www.MessageHeader@cc285f419 pairs: {null: HTTP/1.1 500 Internal Server Error}{Cache-Control: private}{Transfer-Encoding: chunked}{Content-Type: text/plain; charset=utf-8}{Server: Microsoft-IIS/8.5}{X-TFS-ProcessId: f968ad58-674d-4bdd-9b09-96cd9ba9a64c}{ActivityId: 1ba73d49-3e1e-471c-9e6c-d8a73a5d3f3b}{X-TFS-Session: 1ba73d49-3e1e-471c-9e6c-d8a73a5d3f3b}{X-VSS-E2EID: 1ba73d49-3e1e-471c-9e6c-d8a73a5d3f3b}{X-FRAME-OPTIONS: SAMEORIGIN}{X-VSS-UserData: 8857810f-8109-444e-b448-37cbe4b6de34:emmall}{X-TFS-Exception: GitProtocolException}{X-AspNet-Version: 4.0.30319}{Persistent-Auth: true}{X-Powered-By: ASP.NET}{P3P: CP="CAO DSP COR ADMa DEV CONo TELo CUR PSA PSD TAI IVDo OUR SAMi BUS DEM NAV STA UNI COM INT PHY ONL FIN PUR LOC CNT"}{Lfs-Authenticate: NTLM}{X-Content-Type-Options: nosniff}{Date: Wed, 22 Nov 2017 00:03:51 GMT}
Exception in thread "main" java.io.IOException: Server returned HTTP response code: 500 for URL: https://tfs.synergy.net.au/tfs/Synergy/WBU/_git/STARS/git-receive-pack
at au.net.synergy.wts.security.tools.GitTest.main(GitTest.java:31)
LSA: Found Ticket
LSA: Made NewWeakGlobalRef
LSA: Found PrincipalName
LSA: Found DerValue
LSA: Found EncryptionKey
LSA: Found TicketFlags
LSA: Found KerberosTime
LSA: Found String
LSA: Found DerValue constructor
LSA: Found Ticket constructor
LSA: Found PrincipalName constructor
LSA: Found EncryptionKey constructor
LSA: Found TicketFlags constructor
LSA: Found KerberosTime constructor
LSA: Finished OnLoad processing
Current Time: Fri Sep 26 02:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.06682 seconds
