What is the proper use of "Restore Related Elements" [message #1773183] |
Fri, 22 September 2017 18:16  |
My question regards the commands access via [Right Click a Block] -> Navigate -> Restore Related Elements. The way I thought this was supposed to work was:
1) I define Block A and Block B and a relationship between A and B
2) I place A on a diagram, invoke Restore Related Elements on A, and B and the associated relationship are added to the diagram
OR
2) I add A and B to a diagram, select A, or B, or both at once, invoke Restore Related Elements, and the relationship between A and B is added to the diagram
Instead, I have yet to get this command to do anything at all...and I could really use some function like that described above. So, my question: How are you guys using this feature...what does is actually do?
--Thanks.
FUDForum. Page generated in 0.03189 seconds
