Home » Eclipse Projects » Eclipse Scout » Eclipse Scout 7.0.100 (Oxygen.1) now available
Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773415] Wed, 27 September 2017 12:11 Go to next message
The latest update of Eclipse Scout is now available for download [1]. Please check out the corresponding release notes [2].
Some minor but notable improvements include:
  • New time picker
  • Clear icons for input fields
  • Improved popup dialogs
[1] https://www.eclipse.org/downloads/eclipse-packages/
[2] https://eclipsescout.github.io/7.0/release-notes.html#clear-icon-for-input-fields-since-7-0-100
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773417 is a reply to message #1773415] Wed, 27 September 2017 12:18 Go to previous messageGo to next message
Also check out the great new #JavaScript only widgets demo application [1].
[1] https://scout.bsi-software.com/jswidgets/
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773464 is a reply to message #1773417] Thu, 28 September 2017 03:48 Go to previous messageGo to next message
Matthias Zimmermann wrote on Wed, 27 September 2017 16:18
You should also link it on https://www.eclipse.org/scout/ in the demo appications section.
Is there a beginner's guide for ScoutJS available?
Also, which is the Mavin artifact version for the new release? On https://wiki.eclipse.org/Scout/Updatesites, there is still 7.0.0.008_Oxygen given as the release version.
[Updated on: Thu, 28 September 2017 03:57] by Moderator
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773665 is a reply to message #1773464] Mon, 02 October 2017 10:39 Go to previous messageGo to next message
Hi Benjamin,
the most recent version is 7.0.100.017_Oxygen_1, see here https://eclipsescout.github.io/7.0/release-notes.html#obtaining-the-latest-version.
A beginners guide for Scout JS is not available yet. But you will find some information in the technical guide https://eclipsescout.github.io/7.0/technical-guide.html#scout-js. Also check out the source code for the js widgets: https://github.com/BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs/tree/releases/7.0.x/code/widgets (the modules named .*jswidgets.*).
Btw: the link for the release notes posted by Matthias points to to a single change. This is the correct link:
https://eclipsescout.github.io/7.0/release-notes.html#oxygen-1-7-0-100-released-on-september-27-2017
And yes, we should definitely update the Scout home page :-)
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773759 is a reply to message #1773665] Wed, 04 October 2017 05:53 Go to previous messageGo to next message
Thanks for the information. :-)
Is there also the source code for the jswidgets example available? I did not find it on github.
I did know about the documentation in the technical guide, but I miss a link to get into the ScoutJS development. I don't know how to begin a ScoutJS project, and also I don't know what to do to extend a normal Scout application JS-side. There are code snippets in the technical guide, but I don't know where to put these snippets.
Sorry for cluttering this release announcement. To go back to the main subject of this thread, I successfully updated my application to 7.0.100 and all problems I faced with 7.0.0 that stopped me from updating my live system are gone. Thanks for the good work.
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1773910 is a reply to message #1773759] Fri, 06 October 2017 08:21 Go to previous messageGo to next message
Yes, the source code for jswidgets is available on github: https://github.com/BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs/tree/releases/7.0.x/code/widgets
There are 4 maven modules, the one with the source code is https://github.com/BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs/tree/releases/7.0.x/code/widgets/org.eclipse.scout.jswidgets.ui.html. It is a bit confusing, that they are located next to the classic widget modules, I suppose we should put them in a separate folder.
To start a new Scout JS project, you can either use the jswidgets modules as template. Or you can use the hellojs application, which I just pushed a few moments ago to github: https://github.com/BSI-Business-Systems-Integration-AG/helloscout
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1777609 is a reply to message #1773910] Thu, 30 November 2017 12:40 Go to previous messageGo to next message
I was with version 6.0.
I am trying to upgrade. I read the migration guides from 6.0.x to 6.1, and from 6.1 to 7.0. I use the "latest stable" version, 7.0.100.017_Oxygen_1.
However, I find that most of the java API changes are not mentioned. Some AbstractTableFieldData becomes (apparently?) AbstractTableFieldBeanData, AbstractDesktop.setOutlines now doesn't accept an IOutline (which is what I get from getAvailableOutlines()) but there is setOutlineInternal(IOutline) : maybe I should use it instead, some constants changed their owning class, etc.
Edit: Ok for ITableRaw I found it on the migration guide, I was probably absent minded in this one.
Am I missing something or is it a work in progress ?
Thanks.
[Updated on: Thu, 30 November 2017 13:03] by Moderator
Re: Eclipse Scout 7.0.100 (Oxygen.1) now available [message #1777648 is a reply to message #1777609] Fri, 01 December 2017 04:18 Go to previous message
Hi Michael,
thank you for your feedback.
The migration notes for desktop.setOutline and AbstractTableFieldData were missing indeed, I updated the guide accordingly: http://eclipsescout.github.io/6.1/migration-guide.html
Best regards
Claudio
Previous Topic:How to reorder fields in a composite field ?
Next Topic:ODATA With Eclipse Scout
Current Time: Sat Jul 26 11:28:02 EDT 2025
Powered by FUDForum. Page generated in 0.10387 seconds
