Home » Language IDEs » Java Development Tools (JDT) » Eclipse can not be started
Eclipse can not be started [message #1773307] Tue, 26 September 2017 06:46 Go to next message
Eclipse Oxygen can not be started - during the first run I am select a directory as workspace, click on Launch and see message report:
"An error has occured. See the log file.."
This is a log file:
"!SESSION 2017-09-26 12:37:46.585 -----------------------------------------------
eclipse.buildId=4.7.0.I20170612-0950
java.version=9
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=ru_RU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 4 0 2017-09-26 12:38:01.040
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
... 22 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-09-26 12:38:01.040
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
... 21 more
Help me please!
  • Attachment: .log
    (Size: 6.04KB, Downloaded 483 times)
  • Attachment: .log
    (Size: 6.04KB, Downloaded 443 times)
Re: Eclipse can not be started [message #1773382 is a reply to message #1773307] Wed, 27 September 2017 03:19 Go to previous messageGo to next message
I got exactly the same thing, did you play around with the Environment variables or move important Java files?
Re: Eclipse can not be started [message #1773387 is a reply to message #1773307] Wed, 27 September 2017 04:07 Go to previous messageGo to next message
Until Oxygen 1a is released next month, you have to follow these steps to run with Java 9: https://wiki.eclipse.org/Configure_Eclipse_for_Java_9#Configure_Eclipse_for_Java_9_modules
Re: Eclipse can not be started [message #1773680 is a reply to message #1773387] Mon, 02 October 2017 14:30 Go to previous messageGo to next message
Hey,
Is your issue fixed? Are you able to run selenium with JAVA 9.
I f yes, then please share the resolution steps.
I am also stuck in the problem same as yours.
Thanks in advance.
REgards
Re: Eclipse can not be started [message #1773868 is a reply to message #1773680] Thu, 05 October 2017 12:08 Go to previous messageGo to next message
What part of the Wiki instructions did you try? What does your eclipse.ini look like?
Re: Eclipse can not be started [message #1783297 is a reply to message #1773868] Sun, 11 March 2018 01:57 Go to previous messageGo to next message
At other site I found how to fix it.
So... this works:
From the eclipse.ini:
-vmargs
--add-modules=java.se.ee
-Dosgi.requiredJavaVersion=1.8
-Xms256m
-Xmx1024m
P. S. Also I add -vm before -vmargs and I dont't know how important is it...
-vm
C:\Program Files\Java\jdk-9.0.4\bin\javaw.exe
Re: Eclipse can not be started [message #1792216 is a reply to message #1783297] Thu, 12 July 2018 12:54 Go to previous message
add-modules fixed the issue, thanks.
Previous Topic:no auto update after change pom.xml
Next Topic:Can Java compile and run within Eclipse?
Current Time: Sun Aug 31 05:19:41 EDT 2025
Powered by FUDForum. Page generated in 0.04171 seconds
