Home » Modeling » Graphiti » could't save the Graphiti(Some resources could not be saved, see details for more information)
could't save the Graphiti [message #1773101] Thu, 21 September 2017 09:46 Go to next message
Hi, every friend fo this forum,
I met a problem in this week, but now I have no idea to fix it.
The grapiti file could't be save in the most projects. Sometimes I can save it at first, but when I close it and open it again, I can't save it again.
The detail as follow, can you give me some suggestions to fix it ??
_________________________________________________
platform:/resource/RailGround_Structure/src/diagrams/newDiagram.diagram
The object 'org.eclipse.graphiti.mm.pictograms.impl.FreeFormConnectionImpl@7fafc405 (visible: true, active: true)' is not contained in a resource.
Re: could't save the Graphiti [message #1773146 is a reply to message #1773101] Fri, 22 September 2017 04:09 Go to previous messageGo to next message
That looks like an issue with the EMF resource assignment: whenever you create a new EMF object (in this case a FreeFormConnection) you have to make sure to add it to an EMF resource (in Graphiti case usually the one that also holds the diagram).
MIchael
Re: could't save the Graphiti [message #1773338 is a reply to message #1773146] Tue, 26 September 2017 10:41 Go to previous messageGo to next message
Michael Wenz wrote on Fri, 22 September 2017 08:09
MIchael
_______________
Hi, MIchael, thanks for your kind reply.
I tried to do find the error in these days according to your suggestion, but failed. I try find some ways to do.
Re: could't save the Graphiti [message #1773339 is a reply to message #1773146] Tue, 26 September 2017 10:42 Go to previous messageGo to next message
MIchael
_______________
Re: could't save the Graphiti [message #1773340 is a reply to message #1773146] Tue, 26 September 2017 10:42 Go to previous messageGo to next message
MIchael
_______________
Re: could't save the Graphiti [message #1773341 is a reply to message #1773146] Tue, 26 September 2017 10:42 Go to previous messageGo to next message
MIchael
_______________
Re: could't save the Graphiti [message #1773342 is a reply to message #1773146] Tue, 26 September 2017 10:42 Go to previous message
_______________
Previous Topic:Direct Editing in Pattern approach
Next Topic:Problems while modifying EList of string
Current Time: Sun May 11 21:35:01 EDT 2025
Powered by FUDForum. Page generated in 0.02378 seconds
