Home » Newcomers » Newcomers » installing eclipse on macbook air(An error has occurred. See the log file /Users/raymart/eclipse-workspace/.metadata/.log.)
installing eclipse on macbook air [message #1773267] Mon, 25 September 2017 16:03 Go to next message
Tried installing eclipse oxygen for the first time on this new macbook air (new to macOS), today. Here's the error
!SESSION 2017-09-25 12:42:03.708 -----------------------------------------------
eclipse.buildId=4.7.0.I20170612-0950
java.version=9
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/raymart/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.java.product -keyring /Users/raymart/.eclipse_keyring
!ENTRY org.eclipse.osgi 4 0 2017-09-25 12:42:11.733
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
... 22 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-09-25 12:42:11.742
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
... 21 more
Re: installing eclipse on macbook air [message #1773268 is a reply to message #1773267] Mon, 25 September 2017 16:20 Go to previous messageGo to next message
None of the released Eclipse versions work out-of-the-box with Java 9; those versions will come next month starting with Oxygen.1a. Follow these instructions to get the older version to work with Java 9: https://wiki.eclipse.org/Configure_Eclipse_for_Java_9#Configure_Eclipse_for_Java_9_modules , or go back to Java 8 for now.
Re: installing eclipse on macbook air [message #1773270 is a reply to message #1773268] Mon, 25 September 2017 18:41 Go to previous message
Nitin Dahyabhai wrote on Mon, 25 September 2017 20:20
thank you!
Previous Topic:Loading .epf file automatically at startup
Next Topic:Error on launching Eclipse Oxygen
Current Time: Thu Sep 04 10:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.31733 seconds
