Home » Eclipse Projects » Paho » mqtts protocol?(Connection issues using mqtts protocol)
mqtts protocol? [message #1773176] Fri, 22 September 2017 14:17 Go to next message
I have the following connection string from one of my development portals:
mqtts://0514da43-afd0-482b-ba9e-ab61772d3fb3:LWdrwd_B52PG4JH0@mqtt.helium.com:28103
I'm trying to use the Sample class in the Java Paho client and I'm getting the following exception:
Exception in thread "main" java.lang.IllegalArgumentException: mqtts://0514da43-afd0-482b-ba9e-ab61772d3fb3:LWdrwd_B52PG4JH0@mqtt.helium.com:28103
at org.eclipse.paho.client.mqttv3.MqttConnectOptions.validateURI(MqttConnectOptions.java:529)
at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:378)
at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:270)
at org.eclipse.paho.client.mqttv3.MqttClient.<init>(MqttClient.java:228)
at com.rfidcollect.iot.Sample.<init>(Sample.java:250)
at com.rfidcollect.iot.Sample.main(Sample.java:177)
I've already modified the sample code to not use tcp: as the protocol. Here are the arguments to the execution of the Sample class:
-a subscribe -t 0514da43-afd0-482b-ba9e-ab61772d3fb3/atom/6081f9fffe000957/rx/# -b mqtts://0514da43-afd0-482b-ba9e-ab61772d3fb3:LWdrwd_B52PG4JH0@mqtt.helium.com -p 28103
Thank you in advance,
Chuck
Re: mqtts protocol? [message #1773239 is a reply to message #1773176] Mon, 25 September 2017 05:27 Go to previous messageGo to next message
Hi Chuck,
mqtt or mqtts isn't an official uri scheme (https://www.iana.org/assignments/uri-schemes/uri-schemes.xhtml) so that would be unlikely to work.
If you check the code where the exception was thrown, you'll see that only tcp, ws, wss, ssl and local are valid and accepted URI schemes. (https://github.com/eclipse/paho.mqtt.java/blob/master/org.eclipse.paho.client.mqttv3/src/main/java/org/eclipse/paho/client/mqttv3/MqttConnectOptions.java#L526)
I imagine that you've got mqtts instead of mqtt to indicate that it's a secure connection? If that's the case, you'll want to use the ssl uri scheme and use the SSL arguments (v / k / w / r)
Re: mqtts protocol? [message #1822722 is a reply to message #1773239] Thu, 12 March 2020 05:22 Go to previous message
Hi @James Sutton
I'm not sure whether ws, wss supported URI schemes. Do you
Previous Topic:Java MQTT5 implementation
Next Topic:How correct method for test my mqtt client with Junit 5?
Current Time: Mon Jul 21 02:38:10 EDT 2025
Powered by FUDForum. Page generated in 0.26558 seconds
