Home » Modeling » TMF (Xtext) » tycho question. postpone xtend source code generation(xtext application building via maven)
tycho question. postpone xtend source code generation [message #1772561] Tue, 12 September 2017 08:36 Go to next message
Hello
Could you please clarify the following behavior. When I run build of my application via maven I Observe the maven each time generates a few xtend file like
MyDslRuntimeModule.xtend
MyDslStandaloneSetup.xtend
MyDslGenerator.xtend - last one contains default implementation of my dsl generator.
In my case these classes were implemented in pure java.
How can I postpone creating of this classes?
The same situation I observe in ui plugin. In case I work in Eclipse IDE I do it one time running MWE2 workflow for my dsl.
So I need to configure the same behavior in maven build like in manually build in Eclipse IDE. I have to run MWE2 workflow only if definition of my DSL is changed
Thank you in advance
Alex
[Updated on: Tue, 12 September 2017 08:52] by Moderator
Re: tycho question. postpone xtend source code generation [message #1772568 is a reply to message #1772561] Tue, 12 September 2017 10:26 Go to previous messageGo to next message
Hi, i dont understand the problem. can you please explain. if you configure the xtend-maven-plugin correct bidirectional interoperation with java should work fine.
if you dont want xtend stubs to be generated by the workflow you have to have a look at the workflow as follows
(just a example, might be buggy at some places, needs to be adaped to your fragments)
code = {
				preferXtendStubs = false
				encoding = "US-ASCII"
				lineDelimiter = "\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
			outline= {
				generateXtendStub = true
Re: tycho question. postpone xtend source code generation [message #1772572 is a reply to message #1772568] Tue, 12 September 2017 10:47 Go to previous messageGo to next message
OK, try to explain more detailed
Scenario 1
1. Create new Xtext project via Eclipse for a DSL (org.mycompany.MyDsl for example)
2. Select file GenerateMyDsl.mwe2 and run it as MWE2Workflow
Result is generated xtend stub for org.mycompany.mydsl plugin and for org.mycompany.mydsl.ui plugin.
Then I extend my DSL for my business need. If change something in MyDsl definition
I run GenerateeMyDsl.mwe2 again.
Scenario 2
1. Create new Xtext project via Eclipse for a DSL and use maven as default builder
in case user run mvn package command (for example ). Each build starts from generating code and stub via process defined in GenerateMyDsl.mwe2
My question is :
Are the way to configure maven build that
- skip running GenerateMyDsl.mwe2
- user run GenerateMyDsl.mwe2 via option in command line
Seems to me I can resolve this issue via creating maven profile. Are there anothe ways?
Re: tycho question. postpone xtend source code generation [message #1772573 is a reply to message #1772572] Tue, 12 September 2017 11:05 Go to previous messageGo to next message
the only thin k that terminines java or xtend is the workflow so change it
Re: tycho question. postpone xtend source code generation [message #1772575 is a reply to message #1772573] Tue, 12 September 2017 11:17 Go to previous messageGo to next message
I'm sorry
What does mean "thin k" in your answer?
So if user run maven build MWE2 workflow will executed each time?
MWE2 workflow creates stub for example for DSLGenerator so
In this case if user change something in DSLGenerator
it will be overwritten by MWE2 workflow?
Seems to me I did not understand something
Re: tycho question. postpone xtend source code generation [message #1772576 is a reply to message #1772575] Tue, 12 September 2017 11:27 Go to previous messageGo to next message
Should read thing
Re: tycho question. postpone xtend source code generation [message #1772578 is a reply to message #1772576] Tue, 12 September 2017 11:29 Go to previous messageGo to next message
And the workflow decides if Java or xtend stub is generated and will usually not override existing files
Re: tycho question. postpone xtend source code generation [message #1772631 is a reply to message #1772578] Wed, 13 September 2017 05:30 Go to previous message
Hello Christian
Thank you for suggestions.
The following fixes helped me
code = {
				encoding = "windows-1252"
				lineDelimiter = "\r\n"
				[b]preferXtendStubs=false[/b]
The option preferXtendStubs gives me expected results.
Previous Topic:How to specify an array value in mwe2
Next Topic:Error during building the .web project due to Xtext builder
Current Time: Fri Jul 25 09:56:14 EDT 2025
Powered by FUDForum. Page generated in 0.04951 seconds
