Home » Newcomers » Newcomers » Team menu not showing after installing eGit in Eclipse Oxygen(Team menu not showing after installing eGit in Eclipse Oxygen)
Team menu not showing after installing eGit in Eclipse Oxygen [message #1772435] Sat, 09 September 2017 14:15 Go to next message
After installing eGit into Eclipse Oxygen, I do not see the Team menu item.
From what I can tell via Preferences / Team / Git / Configuration, everything should be hooked up to my GitHub.com project.
I made a small change and saved, but that does not seem to cause the Team menu (I assume it is a top-level menu) to appear.
What else do I need to do to make the Team menu appear in Eclipse Oxygen?
Re: Team menu not showing after installing eGit in Eclipse Oxygen [message #1772450 is a reply to message #1772435] Sun, 10 September 2017 12:41 Go to previous message
It is not a top-level menu. It is a context menu since each project could use a different SCM, or no SCM.
Previous Topic:Unhandled event loop exception and outOfMemory when sharing project
Next Topic:Invalid certificate while installing eclipse
Current Time: Sun Jul 20 21:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.33183 seconds
