Home » Language IDEs » C / C++ IDE (CDT) » Eclipse debugger expression window using matrixes(Eclipse debugger does not show input matrix as expected in "Expression" window)
Eclipse debugger expression window using matrixes [message #1772164] Wed, 06 September 2017 04:51 Go to next message
I am trying to run the below code in the Eclipse debugger and view the matrixes in the "Expression" window. I have set a breakpoint in "myFunction()" at the first for-loop and executed the program until this point. Then I added the "myGlobalMatrix" and "myInputMatrix" to the "Expression" window. In the "Expression" window I can see "myGlobalMatrix" with the [3][4] dimensions and the values inside properly. The "myInputMatrix" shows (*)[4] instead of [3][4] even if the size of the matrix is the same. When looking into the "myInputMatrix" it shows "0,10,20,0" which is the first value in each inner dimension. However, the last 0 is outside the matrix. In order to show "myInputMatrix" correctly in the "Expression" window, "Display As Array" needs to be used by rightclick on the type of "myInputMatrix" and choose the right length of the outer dimension (3).
Why is this extra step needed when looking at input matrixes to a function and not to global matrixes ?
If this is not done, the "myInputMatrix" in "Expression" window does not make any sense.
Ex:
#include <stdio.h>
#include <stdlib.h>
int myGlobalMatrix[3][4] =
{{0, 1, 2, 3},
{10, 11, 12, 13},
{20, 21, 22, 23}};
int myFunction(int myInputMatrix[3][4]);
int sum,i,j;
for (i=0; i < 3; i++)
for (j=0; j < 4; j++)
sum += myInputMatrix[i][j];
return sum;
int main(void)
int mySum = 0;
mySum = myFunction(myGlobalMatrix);
return EXIT_SUCCESS;
Re: Eclipse debugger expression window using matrixes [message #1772424 is a reply to message #1772164] Sat, 09 September 2017 00:42 Go to previous message
This is likely a bug in the GDB/CDT interface.
Here's something that sort of works: (*myInputMatrix@4)
Looks like:
index.php/fa/30678/0/
I came across this some time ago and don't know where this is documented
Note that it assumes a square matrix (i.e., int [4][4]).
I'm not sure how to make it [3][4]
Every attempt causes an error.
What also works is to cast to type int [][4]
then display with myInputMatrix[x] where x is {0:2}
index.php/fa/30679/0/
UPDATE:
The expressions appear to be the same as those used by GDB.
For GDB 5:
https://ftp.gnu.org/pub/old-gnu/Manuals/gdb-5.1.1/html_chapter/gdb_9.html#SEC54
https://sourceware.org/gdb/onlinedocs/gdb/Arrays.html
A newer one (for GDB 8): https://www.sourceware.org/gdb/onlinedocs/gdb.html
You may also find this helpful: https://stackoverflow.com/questions/19497339/how-to-print-2d-arry-values-in-gdb
[Updated on: Sat, 09 September 2017 19:55] by Moderator
Previous Topic:GLFW Arguements Read as Invalid
Next Topic:How to Activate a Plugin when leaving the "New Project" Wizard
Current Time: Mon Jul 21 00:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.03978 seconds
