RAP Display background-image CSS attributes [message #1772077] |
Tue, 05 September 2017 06:18  |
Are there plans to support CSS tags background-repeat and background-position for RAP objects?
In particular I would like this on the Display so that I can provide a customised image while the application is starting up (by default the gradient grey background image).
Ideally to support non-repeating in both directions and centred image e.g. "loading application... please wait..." image in the centre of a corporately-colours image.
background-repeat: no-repeat;
background-position: middle;
I'm not sure if there is a valid 'middle' value in CSS for position, but surely there is a way to achieve this?
Thanks, John
Re: RAP Display background-image CSS attributes [message #1772172 is a reply to message #1772130] |
Wed, 06 September 2017 06:15  |
Thank-you Chris - that is a better way to do it.
In my application's Configuration#configure method I register any images I need:
application.addResource( "splash/loading.png", new ResourceLoader() {
public InputStream getResourceAsStream( String resourceName ) throws IOException {
return this.getClass().getClassLoader().getResourceAsStream( "splash/loading.png" );
...then set the body html:
epProps.put( WebClient.BODY_HTML, "<div id='splash' style='text-align: center;'><br><br><img src='rwt-resources/splash/loading.png'/></div>" );
A hard-coded HTML string like this works OK, but a static html file would be nicer. I couldn't get that to work though.
I've hard-coded the image references with rwt-resources on the front, as I'm unable to call RWT.getResourceManager().getLocation in this method due to invalid thread access, but it is consistent, so that's OK for me.
Thanks, John
FUDForum. Page generated in 0.03971 seconds
