Home » Modeling » Compare » NPE when comparing with HEAD (EGit)
NPE when comparing with HEAD (EGit) [message #1771930] Fri, 01 September 2017 05:05 Go to next message
I'm exploring the capabilities of EMF Compare and the EGit support and I'm stuck on the following issue:
I have a model file committed in my repository
I make some changes in that file
Then I try to use `Compare with > HEAD Revision`
It opens the compare editor properly but everytime I try to double click on a model node I get the following NPE:
!ENTRY org.eclipse.ui 4 0 2017-09-01 10:53:58.551
!MESSAGE Unhandled event loop exception
!STACK 0
	at org.eclipse.emf.compare.rcp.ui.internal.util.MergeViewerUtil.getResourceViaMatch(MergeViewerUtil.java:221)
	at org.eclipse.emf.compare.rcp.ui.internal.util.MergeViewerUtil.getResource(MergeViewerUtil.java:196)
	at org.eclipse.emf.compare.ide.ui.internal.contentmergeviewer.tree.provider.TreeMergeViewerItemContentProvider.createBasicContainer(TreeMergeViewerItemContentProvider.java:1000)
	at org.eclipse.emf.compare.ide.ui.internal.contentmergeviewer.tree.provider.TreeMergeViewerItemContentProvider.getParent(TreeMergeViewerItemContentProvider.java:95)
	at org.eclipse.emf.compare.ide.ui.internal.contentmergeviewer.tree.provider.DelegatingTreeMergeViewerItemContentProvider.getParent(DelegatingTreeMergeViewerItemContentProvider.java:110)
	at org.eclipse.jface.viewers.AbstractTreeViewer.getParentElement(AbstractTreeViewer.java:1690)
	at org.eclipse.jface.viewers.TreeViewer.getParentElement(TreeViewer.java:557)
	at org.eclipse.jface.viewers.AbstractTreeViewer.internalExpand(AbstractTreeViewer.java:1619)
	at org.eclipse.jface.viewers.AbstractTreeViewer.setExpandedState(AbstractTreeViewer.java:2456)
	at org.eclipse.emf.compare.rcp.ui.internal.mergeviewer.impl.TreeMergeViewer.setExpandedState(TreeMergeViewer.java:101)
	at org.eclipse.emf.compare.ide.ui.internal.contentmergeviewer.tree.TreeContentMergeViewer$ExpandCollapseListener.handleEvent(TreeContentMergeViewer.java:519)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5252)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1374)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1357)
	at org.eclipse.swt.widgets.Tree.gtk_test_expand_row(Tree.java:2396)
	at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2007)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5518)
	at org.eclipse.swt.internal.gtk.OS._gtk_tree_view_expand_row(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_tree_view_expand_row(OS.java:13188)
	at org.eclipse.swt.widgets.Tree.showItem(Tree.java:3925)
	at org.eclipse.swt.widgets.Tree.setSelection(Tree.java:3740)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:308)
	at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2504)
	at org.eclipse.jface.viewers.StructuredViewer.setSelectionToWidget(StructuredViewer.java:1759)
	at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2959)
	at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1715)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1075)
	at org.eclipse.emf.compare.rcp.ui.internal.mergeviewer.impl.AbstractStructuredMergeViewer.setSelection(AbstractStructuredMergeViewer.java:111)
	at org.eclipse.emf.compare.ide.ui.internal.contentmergeviewer.EMFCompareContentMergeViewer.updateContent(EMFCompareContentMergeViewer.java:286)
	at org.eclipse.compare.contentmergeviewer.ContentMergeViewer.internalRefresh(ContentMergeViewer.java:802)
	at org.eclipse.compare.contentmergeviewer.ContentMergeViewer.inputChanged(ContentMergeViewer.java:710)
	at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:286)
	at org.eclipse.compare.CompareViewerSwitchingPane.setInput(CompareViewerSwitchingPane.java:270)
	at org.eclipse.compare.internal.CompareContentViewerSwitchingPane.setInput(CompareContentViewerSwitchingPane.java:192)
	at org.eclipse.compare.CompareEditorInput.internalSetContentPaneInput(CompareEditorInput.java:855)
	at org.eclipse.compare.CompareEditorInput.access$7(CompareEditorInput.java:853)
	at org.eclipse.compare.CompareEditorInput$10.run(CompareEditorInput.java:793)
	at org.eclipse.compare.CompareEditorInput.feed1(CompareEditorInput.java:779)
	at org.eclipse.compare.CompareEditorInput.access$2(CompareEditorInput.java:778)
	at org.eclipse.compare.CompareEditorInput$4.open(CompareEditorInput.java:660)
	at org.eclipse.compare.CompareViewerPane.open(CompareViewerPane.java:314)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:851)
	at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:44)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:848)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.AbstractStructuredViewerWrapper.access$6(AbstractStructuredViewerWrapper.java:1)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.AbstractStructuredViewerWrapper$5.open(AbstractStructuredViewerWrapper.java:144)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.WrappableTreeViewer.fireOpen(WrappableTreeViewer.java:868)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1163)
	at org.eclipse.emf.compare.ide.ui.internal.structuremergeviewer.WrappableTreeViewer.handleOpen(WrappableTreeViewer.java:908)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:273)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:268)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:308)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4522)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4107)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.bonitasoft.studio.application.BonitaStudioApplication.createAndRunWorkbench(BonitaStudioApplication.java:93)
	at org.bonitasoft.studio.application.BonitaStudioApplication.start(BonitaStudioApplication.java:88)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
It looks like it fails to compute the ancestor resource.
Note that I do not have this issue when comparing 2 local files or 2 commits from my history. Comparing a previous revision with the working tree also fails with the same stack.
Anyone has an hint ? Should I fill a bug ?
Re: NPE when comparing with HEAD (EGit) [message #1772150 is a reply to message #1771930] Wed, 06 September 2017 03:35 Go to previous messageGo to next message
Hi Romain,
Yes, please fill a bug with this stack trace since there seems to be something wrong going on. Could you tell me what kind of models you were comparing? Ecore? UML?
Laurent Goubet
Obeo
Re: NPE when comparing with HEAD (EGit) [message #1772154 is a reply to message #1772150] Wed, 06 September 2017 03:49 Go to previous messageGo to next message
Nevermind. This was bug 518756 and it has been fixed on master. This fix will be available for consumption in Oxygen.1 that will be out in 3 weeks, or you can update your version of EMF Compare to the 3.3.2RC1 that includes this fix.
Laurent Goubet
Obeo
Re: NPE when comparing with HEAD (EGit) [message #1772169 is a reply to message #1772154] Wed, 06 September 2017 05:33 Go to previous message
Thanks a lot Laurent.
That's a great news.
Previous Topic:How handle only merge the right difference into left?
Next Topic:Closing EMF compare dialog after conflict resolution gets stuck
Current Time: Sun Jul 27 12:02:42 EDT 2025
Powered by FUDForum. Page generated in 0.05649 seconds
