Home » Newcomers » Newcomers » 3.2 Much slower in linux compared to winXP!
3.2 Much slower in linux compared to winXP! [message #177211] Sat, 28 October 2006 10:56 Go to next message
Originally posted by: gjh.sdfsf.com
Is eclipse 3.2 optimzed to winXP?
I have both eclipse 3.2 installed for winXP and Ubuntu and it impossible
(very slow performace) to work with in Ubuntu compared to when I use it in
winXP (boths OS are installed on the same computer).
I am considering to downgrade to 3.1 or 3.0 when I use it in Ubuntu but
would like to know if eclipse is not really designed to run under linux.
Re: 3.2 Much slower in linux compared to winXP! [message #177250 is a reply to message #177211] Sat, 28 October 2006 17:19 Go to previous messageGo to next message
In my experience with using Eclipse 3.2 under Ubuntu (and I'm assuming
you're using Dapper Drake) is not Eclipse's optimization but instead
rather the inefficiency of Sun Java under Ubuntu and other Linux
Distributions. An alternative Java Virtual Machine to Sun's Java is
Blackdown Java. While working with Blackdown Java will increase
performance while under Linux, There is no support to my knowledge of
developing or using Blackdown Java with Eclipse. However I myself have
had no issues so far with using Blackdown, there are certainly
differences between the two JVMs.
Re: 3.2 Much slower in linux compared to winXP! [message #177266 is a reply to message #177250] Sat, 28 October 2006 18:33 Go to previous messageGo to next message
"Milyardo" <zachary.milyardo@gmail.com> skrev i en meddelelse
news:ei0hgg$pi9$1@utils.eclipse.org...
>> in winXP (boths OS are installed on the same computer).
> Distributions.
eclipse 3.1 was faster and I used the same sun jsdk, so something has
changed in 3.2 - eventhough it works fine in winXP
Re: 3.2 Much slower in linux compared to winXP! [message #177328 is a reply to message #177250] Mon, 30 October 2006 05:07 Go to previous messageGo to next message
> Distributions.
In my own experience, the default JVM on Ubuntu is not Sun's, but GCJ,
which has a really bad performance compared to Sun's (and probably IBM's).
So you should install Sun or IBM Java, and launch Eclipse with the -vm
argument.
Re: 3.2 Much slower in linux compared to winXP! [message #177476 is a reply to message #177328] Mon, 30 October 2006 12:29 Go to previous message
>>>>> Patrick Godeau <pgodeau_nosp@m_sapex-alma.com>:
> -vm argument.
Setting JAVA_HOME in the environment before launching eclipse, should
also do the trick.
Previous Topic:eclipse folding button
Next Topic:eclipse solaris 64 bit?
Current Time: Tue Nov 11 06:26:29 EST 2025
Powered by FUDForum. Page generated in 0.12103 seconds
