Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Display background-image CSS attributes(None-repeating and positioned Display background-image)
RAP Display background-image CSS attributes [message #1772077] Tue, 05 September 2017 06:18 Go to next message
Are there plans to support CSS tags background-repeat and background-position for RAP objects?
In particular I would like this on the Display so that I can provide a customised image while the application is starting up (by default the gradient grey background image).
Ideally to support non-repeating in both directions and centred image e.g. "loading application... please wait..." image in the centre of a corporately-colours image.
background-repeat: no-repeat;
background-position: middle;
I'm not sure if there is a valid 'middle' value in CSS for position, but surely there is a way to achieve this?
Thanks, John
Re: RAP Display background-image CSS attributes [message #1772130 is a reply to message #1772077] Tue, 05 September 2017 16:56 Go to previous messageGo to next message
I use the org.eclipse.rap.ui.branding extension point to supply a body html fragment
<div id="splash" style="position: absolute; margin-left: -75px; margin-top: -50px; left: 50%; top: 50%; width: 150px; border: 1px solid #c0c0c0; background-color: #fafafa; text-align: center;">
  <img src="./loading.gif" width="32" height="32" style="margin: 10px 15px 0" />
  <div style="margin: 5px 15px 10px; color: #656565; font: 12px Verdana, 'Lucida Sans', sans-serif">
    application loading ...
  </div>
</div>
loading.gif is in the same dir as the body.html fragment.
I never bothered to change the background gradient. That should be controlled by the theme.
Re: RAP Display background-image CSS attributes [message #1772172 is a reply to message #1772130] Wed, 06 September 2017 06:15 Go to previous message
Thank-you Chris - that is a better way to do it.
In my application's Configuration#configure method I register any images I need:
application.addResource( "splash/loading.png", new ResourceLoader() {
public InputStream getResourceAsStream( String resourceName ) throws IOException {
return this.getClass().getClassLoader().getResourceAsStream( "splash/loading.png" );
...then set the body html:
epProps.put( WebClient.BODY_HTML, "<div id='splash' style='text-align: center;'><br><br><img src='rwt-resources/splash/loading.png'/></div>" );
A hard-coded HTML string like this works OK, but a static html file would be nicer. I couldn't get that to work though.
I've hard-coded the image references with rwt-resources on the front, as I'm unable to call RWT.getResourceManager().getLocation in this method due to invalid thread access, but it is consistent, so that's OK for me.
Thanks, John
Previous Topic:Session timeout in RAP seems not working
Next Topic:Unable to Install RAP Target
Current Time: Sat Jul 26 21:26:25 EDT 2025
Powered by FUDForum. Page generated in 0.14668 seconds
