Home » Eclipse Projects » Kura » OPCUA Driver for kura 3.0.0(OPCUA Driver for kura 3.0.0)
OPCUA Driver for kura 3.0.0 [message #1763730] Fri, 19 May 2017 03:22 Go to next message
HI,
I am trying kura wires. I have installed the opcua driver from eclipse marketplace. My opcua server nodeIds are in "numeric type" , is this a problem when configuring an asset ? I mean OPcUaMessages.nodeId should be a string ???
Any problem connecting with my opcua server but error reading the nodeId...
17:03:20,283 [DefaultQuartzScheduler_Worker-2] ERROR WireAsset:326 - OpcUaMessages.errorRetrievingNodeId
Any suggestion ??
Re: OPCUA Driver for kura 3.0.0 [message #1763783 is a reply to message #1763730] Fri, 19 May 2017 11:37 Go to previous messageGo to next message
Hi Blanca,
could you please detail your setup?
In any case, current implementation only supports String-based node ids, so the failure with a numeric nodeId can be related to this.
Matteo
Re: OPCUA Driver for kura 3.0.0 [message #1771964 is a reply to message #1763783] Fri, 01 September 2017 11:33 Go to previous messageGo to next message
I have same problem but I use string for id on my opcua server, I also try with kura opcua simulator as describe on kura wire documentation but the error is still here.
Benjamin
Re: OPCUA Driver for kura 3.0.0 [message #1772109 is a reply to message #1771964] Tue, 05 September 2017 11:54 Go to previous message
Hi Blanca and Benjamin,
You can try the Developer Preview of the next version of the OPC-UA Driver available on Eclipse Marketplace (https://marketplace.eclipse.org/content/opc-ua-driver-kura-developer-preview).
The new version adds support for more Node IDs, including numeric ones, and should hopefully also fix the reported issue.
Please keep in mind that a direct upgrade is not supported on Kura 3.0.0, before installing the new version make sure to delete any existing wire graph and remove the old deployment package.
Nicola
Previous Topic:Kura PWM?
Next Topic:I2C read command hangs
Current Time: Wed Jul 30 06:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.04525 seconds
