Home » Modeling » UML2 Tools » XMI to UML
XMI to UML [message #1771545] Sun, 27 August 2017 10:26 Go to next message
Hi, I have to create plugin in eclipse for reverse engineering from DDL script to UML schema relational database. I've used JSQLParser, created Java represation and XMI file. Now I have to generate UML schema from that XMI file. How can I do that?
Re: XMI to UML [message #1771622 is a reply to message #1771545] Mon, 28 August 2017 13:27 Go to previous messageGo to next message
This was the newsgroup for the UML2 Tools graphical UML support. It is now pretty much dead; superseded by Papyrus. This is a model transformation question better suited to the MMT newsgroup.
Since you have converted your DDL script to XMI you presumably have a DDL model that you 'just' need to convert to a UML model. UML to RDBMS is the stock example for many M2M languages and papers. Unfortunately most implementations differ in their support for subtleties such as (multiple) inheritance, compound attributes, name clashes, ... so there is no standard implementation. You need the opposite direction and so you could use the inverse of the QVTr bidirectional exposition in the QVT specification or search the literature for a better exercised bidirectional version.
Ed Willink
Re: XMI to UML [message #1771833 is a reply to message #1771622] Thu, 31 August 2017 04:20 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 31 August 2017 04:53] by Moderator
Re: XMI to UML [message #1771834 is a reply to message #1771622] Thu, 31 August 2017 04:21 Go to previous messageGo to next message
Thank you for your answer
Re: XMI to UML [message #1771926 is a reply to message #1771622] Fri, 01 September 2017 04:28 Go to previous messageGo to next message
I still haven't find the solution for this. So I'm gonna be more specific.
This is DDL script for example:
CREATE TABLE TABLE
Column1 VARCHAR COLLATE utf8_unicode_ci,
Column2 TINYINT UNSIGNED NOT NULL,
PRIMARY KEY (Column1)
and I've got this xml file:
<uml:Model xmlns:uml="http://www.eclipse.org/uml2/5.0.0/UML" xmlns:xmi="http://www.omg.org/spec/XMI/20131001" xmi:id="6fb3c342-4f98-4205-ad9d-3d1bafc5dad4" xmi:version="20131001">
<packagedElement name="Database" xmi:id="82a41c0a-8e79-43aa-b5f8-afd0f3d80ae8" xml:type="uml:Package"/>
<packagedElement name="TABLE" xmi:id="a74a1162-46d1-46a8-bfbb-d502cad593fa" xml:type="uml:Class">
<ownedAttribute name="Column1" xmi:id="4a5f62aa-ce54-4d01-90be-3a0eb71eca15" xml:type="7157ba11-e7a8-41d9-8854-cb6a6a52729e"/>
<ownedAttribute name="Column2" xmi:id="15c70181-dbf9-482c-aa8c-819bb1199150" xml:type="70970c80-ac38-441b-800c-6736c3eae035"/>
<ownedOperation name="PK" xmi:id="1edc5db7-3338-460a-acee-d552333d3106">
<ownedAtribute name="Column1" xmi:id="5449ae61-f297-42c0-bc18-2cc5e505bd1b" xml:type="7157ba11-e7a8-41d9-8854-cb6a6a52729e"/>
</ownedOperation>
</packagedElement>
</uml:Model>
I'm using Papyrus and I have to generate UML class diagram in Papyrus. Is there any way to do this?
[Updated on: Fri, 01 September 2017 04:33] by Moderator
Re: XMI to UML [message #1771928 is a reply to message #1771926] Fri, 01 September 2017 04:58 Go to previous messageGo to next message
Your initial question suggested that you had a schema model, when actually you already have a UML model except that it isn't.
There is an obvious "ownedAtribute" typo for a parameter and many other things look smelly; xml:type, Class not in Package, unresolved types, .... The UML Model editor hates it. I suggest you debug your UML generator or better generate a UML model in memory and then use the Eclipse UML serializer.
Once you have a valid UML model, opening it in Papyrus is pretty trivial. Use the Model Explorer menus.
Ed Willink
Re: XMI to UML [message #1771940 is a reply to message #1771928] Fri, 01 September 2017 07:05 Go to previous messageGo to next message
How can I use Eclipse UML serializer?
Re: XMI to UML [message #1771941 is a reply to message #1771940] Fri, 01 September 2017 07:09 Go to previous message
The UML serializer is used when you request a UMLResource to execute save().
Ed Willink
Previous Topic:news.eclipse.org is shutting down.
Next Topic:quality metrics for UML Class Diagram
Current Time: Thu Jul 24 22:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.09082 seconds
