Home » Modeling » TMF (Xtext) » using qualifiedNameConverter for the output
using qualifiedNameConverter for the output [message #1771731] Tue, 29 August 2017 23:57 Go to next message
Hello Experts,
This is my dsl(or I am trying to implement this)
  augment "/if-mib:IF-MIB/if-mib:ifTable/if-mib:ifEntry"
    status deprecated;
    description
     "An entry containing objects for invoking tests on an
      interface.";
    smiv2:oid "1.3.6.1.2.1.31.1.3.1";
    leaf ifTestId {
      type snmpv2-tc:TestAndIncr;
      status deprecated;
      description
       "This object identifies the current invocation of the
        interface's test.";
      smiv2:max-access "read-write";
      smiv2:oid "1.3.6.1.2.1.31.1.3.1.1";
This is my Xtext grammar.
DatadefStatement:
	ContainerStatement |
	LeafStatement |
	ListStatement |
	LeafListStatement
AugmentStatement:
	'augment' path = SchemaNodeIdentifier
		(augmentsubstatements+= AugmentSubStatement)*
AugmentSubStatement:
	DescriptionStatement |
	UsesStatement |
	LeafStatement |
	StatusStatement |
	UnknownStatement
SchemaNodeIdentifier returns SchemaNodeIdentifier:
	 RootSchemaNodeIdentifier ({SchemaNodeIdentifier.target=current}'/'((prefix=STRINGARG':')? schemaNode=[DatadefStatement]))*
RootSchemaNodeIdentifier returns SchemaNodeIdentifier:
	isAbsolute?='/'? ((prefix=STRINGARG':')?schemaNode=[DatadefStatement])
This is my qualifiedNameProvider
public class YangDefinitionQualifiedNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	@Inject
	private IQualifiedNameConverter qnc;
	public QualifiedNameValueConverter qualifiedNameValueConverter(DatadefStatement d)
		return qualifiedNameValueConverter(d);
I am getting this error:
mismatched input '{' expecting ':'
When I try to implement my grammar,
I am getting an output like mentioned below:
[color=darkred] augment / if-mib:IF-MIB / if-mib:IF-MIB.ifTable / if-mib:IF-MIB.ifTable.ifEntry [/color]
    status deprecated;
    description
      interface.";
    leaf ifTestId {
      status deprecated;
      description
        interface's test.";
I am not using scope provider.
Re: using qualifiedNameConverter for the output [message #1771734 is a reply to message #1771731] Wed, 30 August 2017 00:42 Go to previous messageGo to next message
this makes no sense. mismatched input '{' expecting ':' is a parse error.
this runs before any qualified name providers and qualifiednameconverters
makes no sense as well
have no idea what you try to achieve
Re: using qualifiedNameConverter for the output [message #1771736 is a reply to message #1771734] Wed, 30 August 2017 00:52 Go to previous messageGo to next message
Hi Christian,
Actually yes, qualifiednameprovider doen't make sense. i try it and it doesn't matter if I write it or not.
The actual error is :-
no viable alternative at input '"/if-mib:IF-MIB/if-mib:ifTable/IF-MIB.ifTable.ifEntry"'
I am new in programming, so trying new codes and new techniques.
Kaushal
Re: using qualifiedNameConverter for the output [message #1771737 is a reply to message #1771736] Wed, 30 August 2017 00:54 Go to previous messageGo to next message
This is my dsl
This is what I am trying to achieve.
    status deprecated;
    description
      interface.";
    leaf ifTestId {
      status deprecated;
      description
        interface's test.";
[Updated on: Wed, 30 August 2017 00:55] by Moderator
Re: using qualifiedNameConverter for the output [message #1771740 is a reply to message #1771737] Wed, 30 August 2017 01:32 Go to previous messageGo to next message
yes but i cannot help you. you need to find out whats wrong with your grammar
Re: using qualifiedNameConverter for the output [message #1771742 is a reply to message #1771740] Wed, 30 August 2017 02:25 Go to previous messageGo to next message
Hi Chrisitan,
I have checked my grammar. I have some doubts.
1) I am getting whitespace in between two nodes. Can I get rid of those whitespace? If yes, then How?
/if-mib:IF-MIB /if-mib:ifTable /if-mib:ifEntry
2) Can I use cross-reference with double quotes?
like this:
"if-mib:IF-MIB"
When I am trying to use cross-reference with double quotes, it behaves like string value.
i am using cross-reference for both codes.
Here,
if-mib:IF-MIB
PrefixStatement:ContainerStatement
Re: using qualifiedNameConverter for the output [message #1771747 is a reply to message #1771742] Wed, 30 August 2017 03:06 Go to previous messageGo to next message
as i said in other questions before.
i need a reproducible grammar.
i need a MINIMAL reproduible grammar.
and i like to have a unit test.
otherwise supporting such questions is pain
Re: using qualifiedNameConverter for the output [message #1771750 is a reply to message #1771747] Wed, 30 August 2017 03:32 Go to previous messageGo to next message
This is my grammar.
AugmentStatement:
	'augment' path=SchemaNodeIdentifier
	UsesStatement |
	LeafStatement |
	StatusStatement |
	UnknownStatement
	 RootSchemaNodeIdentifier ({SchemaNodeIdentifier.target=current}'/'((pre=STRINGARG':')?schemaNode=[DatadefStatement]))*
	isAbsolute='/'?((pre=STRINGARG ':')?schemaNode=[DatadefStatement])
Re: using qualifiedNameConverter for the output [message #1771751 is a reply to message #1771750] Wed, 30 August 2017 03:35 Go to previous messageGo to next message
well that grammar is neither minimal nor complete
Re: using qualifiedNameConverter for the output [message #1771752 is a reply to message #1771751] Wed, 30 August 2017 03:50 Go to previous messageGo to next message
DatadefStatement:
	LeafStatement |
	ListStatement |
	LeafListStatement
ContainerStatement:
	'container' name=STRINGARG33 (';' | '{'
		(containersubstatements+= ContainerSubStatement)*
ContainerSubStatement:
	LeafStatement |
	ListStatement |
	LeafListStatement |
	AugmentStatement |
LeafStatement:
	'leaf' name=STRINGARG33 (';' | '{'
		(leafsubstatements+= LeafSubStatement)*
LeafSubStatement:
	ContainerStatement
ListStatement:
	'list' name= (STRINGARG | KEY_IDENTIFIER) (';' | '{'
		(listsubstatements+= ListSubStatement)*
ListSubStatement:
	LeafStatement |
	LeafListStatement |
	ContainerStatement
LeafListStatement:
	'leaf-list' name=STRINGARG ';'
AugmentStatement:
	LeafStatement
STRINGARG:
	ID | 'default' | INT | CUSTOMSTRING ;
CUSTOMSTRING:
	(STRING ('+' STRING)*);
terminal ID:
    ('^')?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'-'|'/'|'.'|'\"'|'0'..'9')*;
Check the attached file for full grammar.
Thanks.
Re: using qualifiedNameConverter for the output [message #1771754 is a reply to message #1771752] Wed, 30 August 2017 04:01 Go to previous message
sorry i want a minimal but complete reproducing grammar and a unit test
Previous Topic:Support EFS in Xtext
Next Topic:Custom scope for only one Resource [solved]
Current Time: Tue Jul 22 09:24:54 EDT 2025
Powered by FUDForum. Page generated in 0.06117 seconds
