[SOLVED] Type resolver replies null [message #1771725] |
Tue, 29 August 2017 18:25  |
Dear all.
I have defined a default value for my formal parameters. My grammar extends Xtend's grammar with:
Parameter returns xtend::XtendParameter:
{SarlFormalParameter} annotations+=XAnnotation*
(extension?='extension' annotations+=XAnnotation*)?
name=ValidID ':' parameterType=JvmTypeReference
( (varArg?='*')
| ('=' defaultValue=XExpression))?
Let the following DSL code:
interface Example {
def fct1(param1 : Object = Collections.emptyList)
def fct2(param2 : boolean = true)
In my validator, I checks if the types of the formal parameter and the default value expression are compatible. To do so, I get the type of the default value expression.
LightweightTypeReference fromType = getExpectedType(defaultValue);
if (fromType == null) {
fromType = getActualType(defaultValue);
For the first function fct1, fromType==Object, as expected. But, when the validator is called on the second function fct2, fromType==null.
If I put any feature call to a static function into the default value of param1, the type of the param2 default value is always null. See that the expression in fct1 have an impact on the validation of the expression into fct2 (strange behavior).
If I changed the default value of param1 to a simple expression (as illustrated below), the type of param2's default value becomes fromType=boolean, as expected.
interface Example {
def fct1(param1 : Object = new Object)
What is missed in my approach?
Thank you by advance.
Stéphane.
[Updated on: Wed, 30 August 2017 07:55] by Moderator
Re: Type resolver replies null [message #1771756 is a reply to message #1771735] |
Wed, 30 August 2017 04:10   |
Type computer does not contain any specific definition related to the parameter's default value (see https://github.com/sarl/sarl/blob/master/main/coreplugins/io.sarl.lang/src/io/sarl/lang/compilation/typesystem/SARLTypeComputer.java)
The JVM model inferrer generates a field that is initialized with the default value. Then two functions are generated: one with the parameter, and one without.
For example:
def fct(a : int, b : Object = Collections::emptyList) {}
generates to:
private static final Object $DEFAULT_VALUE = Collections.emptyList();
public void fct(int a, Object b) {
public final void fct(int a) {
fct(a, $DEFAULT_VALUE);
The generated Java code is always correct.
Nevertheless, the code of the JVM model inferrer is too big to be copied here. In https://github.com/sarl/sarl/blob/master/main/coreplugins/io.sarl.lang/src/io/sarl/lang/compilation/jvmmodel/SARLJvmModelInferrer.java, see lines:
* 2911: the function which generates the list of formal parameters, and the hidden fields.
* 1580: the function that transforms the DSL functions to Java.
* Inside the previous function, between lines 1813 and 1939, the additional function is generated.
Re: Type resolver replies null [message #1771786 is a reply to message #1771776] |
Wed, 30 August 2017 07:52  |
Nice guideline. Thank you.
I have learnt the Xtext node model a long time after I have written this serialization function. And, I did not improve this code. Now, it's done :)
For who want to "serialize" an EObject for obtaining the DSL code:
private def String reentrantSerialize(EObject object) {
var node = NodeModelUtils::getNode(object)
if (node !== null) {
var text = node.text
if (text !== null) {
text = text.trim
return Strings::emptyToNull(text)
return null
FUDForum. Page generated in 1.07311 seconds
