Creating internal transition in UML-RT? [message #1771509] |
Fri, 25 August 2017 16:48  |
Does it need special procedure to create an internal transition, or by simply picking "internal" as kind in UML tab (in properties window) a transition should be an internal one?
As I see unexpected behavior in a state machine with an internal transition. The transition simply does not get triggered:
Unexpected message to capsule instance prop1__TOP.trafficLight role trafficLight on port TestData protocol TestChannel signal nextTest
"trafficLight" is a capsule which its state machine has an internal transition (its kind is "internal"). That internal transition has "nextTest" as its trigger.
Thanks.
[Updated on: Fri, 25 August 2017 18:33] by Moderator
Re: Creating internal transition in UML-RT? [message #1771715 is a reply to message #1771713] |
Tue, 29 August 2017 15:42   |
In UML all elements except for the top-level model are owned by (contained in) some other element. States are owned indirectly by other States or by a State machine. Indirectly because they are owned by a "Region", but in UML-RT, as opposed to general UML, states and state machines own only one region which is why this region is hidden in the model explorer. If a state owns anything (transitions, pseudo-states, other states), then it is composite. So you can add internal transitions (or anything) to a simple state, but that will make it automatically into a composite state. A state machine also owns states, pseudo-states and transitions. Whenever you add any of these to the state machine, it is owned by the state machine. This includes internal transitions, which is just another kind of transition. My statement was that while we do support internal transitions, I think we only support internal transitions owned by a (composite) state and not by the state machine itself (more precisely, internal transitions owned by the state machine's own Region).
FUDForum. Page generated in 0.05418 seconds
