Home » Language IDEs » ServerTools (WTP) » How to publish to my own jUDDI server?
How to publish to my own jUDDI server? [message #176710] Wed, 09 August 2006 10:58 Go to next message
Originally posted by: avinh.verizon.net
When going through the Wizard for creating a Web Service, I get to the
step for publising the WSDL which gives me a drop down window for a set of
UDDI registries to use, what if I want to publish my WSDL document to my
own UDDI server - i.e. I have set up a jUDDI on a Unix server that I would
like to use. How do I tell WTP to use my server's jUDDI registry instead
of the ones in the drop down list?
Thanks - Alan
Re: How to publish to my own jUDDI server? [message #176727 is a reply to message #176710] Wed, 09 August 2006 14:08 Go to previous messageGo to next message
Once you are in the Web Services Explorer you can click on "UDDI Main"
in the Navigator view. From there you can enter the Inquiry URL for
your UDDI server. Then click on "publish" to publish a Business,
Service or Service Interface. To do this you will need to know the
inquiry and publish URLs for your UDDI server.
Perhaps the Publish page of the wizard could be a bit more flexible and
allow you add your own registries to that drop down menu or something.
If you have any ideas or suggestions on how to improve the publish
process you can open an enhancement request in bugzilla.
> of UDDI registries to use, what if I want to publish my WSDL document to
> my own UDDI server - i.e. I have set up a jUDDI on a Unix server that I
> would like to use. How do I tell WTP to use my server's jUDDI registry
> instead of the ones in the drop down list?
> Thanks - Alan
Re: How to publish to my own jUDDI server? [message #176845 is a reply to message #176727] Fri, 11 August 2006 10:18 Go to previous messageGo to next message
Thanks Mark, I'll give that a go to see if it will work for me.
Alan
Re: How to publish to my own jUDDI server? [message #177141 is a reply to message #176727] Wed, 16 August 2006 16:42 Go to previous messageGo to next message
Quick update...
Using Eclipse 3.1.2 and WTP 1.0.2, do the following:
1) run->Launch the Web Services Explorer (WSE)
2) Click on the UDDI page then enter your "Registry Name" along with its
"Inquiry URL". I'm testing jUDDI, so the typical URL for the inquiry URL
is:
http://localhost:8080/juddi/inquiry
3) Click on the "Go" button. If your UDDI interface/URL is working
properly, the WSE will come back with the services for that URL. For
jUDDI, under "Other Actions", they are:
- Find
- Publish
- Add To Favorites
Click on the "Add To Favorites" link and it will add your newly entered
UDDI registry server URL (in my case it is jUDDI) to the drop down list.
Enter the appropriate fields for the "Find" and "Publish" interfaces
accordingly.
Re: How to publish to my own jUDDI server? [message #177146 is a reply to message #177141] Wed, 16 August 2006 17:15 Go to previous messageGo to next message
I'm trying to publish a WSDL to jUDDI using Eclipse 3.1.2 and WTP 1.0.2. I
entered the following information requested for publishing a "Service
Interface":
Publication format -> simple
Publish URL ->
https://seurat.cbt.nist.gov:8443/BisacsRpcWebPortal/services /BisacsPrimaryPortal
User ID -> bisacs
Password -> <I don't believe jUDDI is currently using this field>
WSDL URL ->
platform:/resource/BisacsRpcWebPortal/WebContent/wsdl/Bisacs PrimaryPortal.wsdl
Name -> BISACS
Description -> BISACS Services
I clicked on the "Go" button and it resulted in the following error
message:
IWAB0135E An unexpected error has occurred.
UDDIException
No such operation 'get_authToken'
Anyone know how to fix this problem so that I can go further in the
process in order to get an entry into the jUDDI registry?
Thanks - Alan
Re: How to publish to my own jUDDI server? [message #177162 is a reply to message #177146] Wed, 16 August 2006 17:59 Go to previous messageGo to next message
I have never played around with jUDDI but I can tell you that the
UDDIException probably comes from UDDI4j which the WSE uses to
communicate with uddi registries. get_authToken is used to get an
Authentication token using the username and password.
This could be a bug with the WSE so you could open it against wst.ws in
bugzilla. I have never tried using the WSE with a jUDDI server.
There is also the possibility that your jUDDI server is somehow set up
incorrectly and there is a problem getting the authentication token.
You could try looking in the jUDDI documentation or searching the web
for more info about this.
> I entered the following information requested for publishing a "Service
> Interface":
> Publish URL ->
> User ID -> bisacs
> WSDL URL ->
> Name -> BISACS
> message:
> UDDIException
> Thanks - Alan
Re: How to publish to my own jUDDI server? [message #177177 is a reply to message #177162] Wed, 16 August 2006 19:01 Go to previous messageGo to next message
Thanks for the reply Mark. I've figured out what the problem was, the
fields should have been filled out as follows for publishing my "Service
Interface":
Publish URL ->
https://seurat.cbt.nist.gov:8443/juddi/publish
User ID -> bisacs
WSDL URL ->
https://seurat.cbt.nist.gov:8443/BisacsRpcWebPortal/services /BisacsPrimaryPortal?wsdl
Name -> BISACS
Notice that the "Publish URL" is the URL for the UDDI server/interface
(i.e. where I'm publishing my WSDL document) and NOT where my BISACS
service interface lives. The correct WSDL document URL should also be used
in the "WSDL URL" field - notice the "?wsdl" at the end of the URL.
Once the WSE published my WSDL into jUDDI, I was able to do a "find" on my
service name and the correct data came back.
I hope this thread will help others in the future with using WTP to
publish their WSDL documents into a UDDI registry and then doing a search
for their services.
The WTP package has been really helpful with creating the WSDL documents
for my Web Services AND creating the client code to test the interfaces,
lastly, it published my WSDL documents to a UDDI registy (i.e. jUDDI) -
good stuff, I highly recommend using the WTP plugin for Eclipse. I can
also use the WTP generated sample client code in my other clients to
access my services too which is VERY nice!
Thanks for your help Mark, cheers - Alan
>> Interface":
>> Publish URL ->
>> User ID -> bisacs
>> WSDL URL ->
>> Name -> BISACS
>> message:
>> UDDIException
>> Thanks - Alan
Re: How to publish to my own jUDDI server? [message #177457 is a reply to message #176710] Fri, 18 August 2006 12:30 Go to previous messageGo to next message
I have summarized my effort in creating and publishing a web service below
for anyone who might be interested. This method worked for me. Getting
instructions on how to go through this process was not straight forward so
I have put together the following information for future references.
Hopefully it will help other people get going in the right direction.
Cheers - Alan
Creating and publishing Java Web Services Interfaces using Eclipse and the
Web Tools Platform (WTP).
Software packages that are involved with this process include but not
limited to the following list...
The following were installed on my development machine running Windows XP
Professional.
The Eclipse Integrated Development Environment (IDE) can be found in the
following link, I'm using version 3.1.2:
http://www.eclipse.org/downloads/
The plugin for developing Web Services (WTP) can be found in the following
link, I'm using version 1.0.2:
http://www.eclipse.org/webtools/
Eclipse NewsPortal for webtools is in the following link:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.w ebtools
I'm using the Apache Tomcat Application server along with Axis (for SOAP
services), jUDDI (UDDI registry server) and MySql as the DBMS. All were
installed on a Linux Red Hat version 3 box.
Tomcat can be found in the following link, I'm using version 5.5.17:
http://tomcat.apache.org/
Axis can be found in the following link, I'm using version 1.4:
http://ws.apache.org/axis/
The jUDDI server can be found in the following link, I'm using version
0.9rc4 (UDDI version 2.0):
http://ws.apache.org/juddi/
jUDDI User forum/mailing list is in the following link:
http://www.nabble.com/jUDDI---User-f240.html
MySql download can be found in the following link, I'm using version
5.0.22-linux-i686:
http://dev.mysql.com/downloads/
1) Install and configure the Tomcat Application Server, Axis, jUDDI and
MySql on your target platform/machine, i.e. where your Web Services
Application will finally reside.
2) Install and configure the Tomcat Application Server and Axis on your
development machine. You will need them for integrating with Eclipse.
3) Install and configure Eclipse and WTP on your development machine.
4) Create a Tomcat server in the Eclipse workbench by following the
instructions at the following link:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. jst.ws.axis.ui.doc.user/tasks/ttomcatserv.html
Test and make sure that the installations from steps 1-4 work properly
before continuing.
The following steps are done using the Eclipse IDE along with the WTP
plugin:
5) Create a "Dynamic Web Project" by doing the following inside of Eclipse:
- File->New->Dynamic Web Project
- Give the project an appropriate name and select the "Finish" button.
We'll call it "myApp" as
a reference in this document.
6) Create your Java class with the public methods that you will be using
as your Web Service Interfaces - this is called bottom up web design. Do
this as follows:
- RIGHT click on the "myApp" project and select
New->Class
- Give an appropriate package name (e.g. my.org.name) and class name (e.g.
MyWebClass) and select the "Finish" button.
- Finish coding up the public methods for the "MyWebClass" class.
- Make sure your project has all the required jar files in its "Java Build
Path", i.e. do the following:
RIGHT click on your project and select "Properties", then under "Java
Buile Path" add all the required jar files needed the compile your class.
- Make sure you build your project so that your class is available in the
output folder (e.g. build/classes/...), i.e. do the following to create
the class files:
Project->Build Project
7) RIGHT click on the "MyWebClass" class and do the following to create
the WSDL and the test client:
- Web Services->Create Web Service
- In the "Web Services" window, check the "Generate a proxy" and "Test the
Web service" boxes then select Next->Next->Next.
- In the "Web Service Java Bean Identity" window, notice where your "Web
service URI" is located, this will be the location of your service when
you publish the interface later. You can change the URI in the WSDL
document later. Also notice the "WSDL File" that will be created by the
wizard. To access the WSDL document using a browser, you add the string
"?wsdl" to the end of the "Web service URI" string. The "WSDL File" is
also located in the folder indicated by the field "WSDL Folder".
- Check all methods that you want to be available for your Web Services
interface.
- Select the appropriate "Style and Use" for your interface then click on
the "Next" button
- In the "Server startup page" window, click on the "Start server" button
to start Tomcat.
- Once Tomcat has started successfully, click on the "Next" button.
- In the "Web Services Test Page" window, click on the "Next" button.
- In the "Web Services Proxy Page" window, click on the "Next" button.
- In the "Web Services Client Test" window, make sure the "Run test on
server" option is UNCHECKED then click on the "Next" button.
- In the "Web Services Publication" window, click on the "Finish" button.
8) Once the "Web Services Test Client" window come up, you can test your
interfaces. I have found that testing the interfaces using this mechanism
may result in perculiar behaviors. What works better is to migrate your
project to Tomcat by doing the following on the target machine:
8.1 - Stop Tomcat on the target machine/platform.
8.2 - Create a directory with the SAME name as your project, in this case
it's "myApp", under the following directory -> TOMCAT_HOME/webapps which
should result in something like TOMCAT_HOME/webapps/myApp
8.3 - Copy all contents under the "WebContent" folder for your project
from your development machine (e.g.
C:\EclipseWorkspace\myApp\WebContent\*.*) to the target machine under
TOMCAT_HOME/webapps/myApp.
8.4 - If your Eclipse output folder is defaulted to the "build" folder,
then copy the "classes" folder for your project from your development
machine (e.g. C:\EclipseWorkspace\myApp\build\classes) to the target
machine under TOMCAT_HOME/webapps/myApp/WEB-INF.
8.5 - You should now have a similar directory structure as the following
on your target machine:
--> TOMCAT_HOME/webapps/myApp/META-INF
--> TOMCAT_HOME/webapps/myApp/WEB-INF
--> TOMCAT_HOME/webapps/myApp/WEB-INF/classes
--> TOMCAT_HOME/webapps/myApp/wsdl
8.6 - Eclipse should have created the client application project that you
can use to test your Web Services, it has the same name as your project's
name with the word "Client" appended to it, for this discussion it would
be "myAppClient". The code for the client can be used to create your own
client classes to access your Web Service Interfaces, so you can make good
use of it.
8.7 - Repeat steps 8.2-8.5 and migrate the client application (e.g.
myAppClient) to TOMCAT/webapps too.
9) Start Tomcat on the target machine and Tomcat should recognize your new
web applications located under the TOMCAT_HOME/webapps directory. You can
access and test the "myApp" Web Services by running the "myAppClient" JSP
that was created by Eclipse. The typical URL for the client JSP is as
follows (notice that it uses your application name and class name):
http://localhost:8080/myAppClient/sampleMyWebClass/TestClien t.jsp
10) Make changes to your "MyWebClass" accordingly using Eclipse and copy
the "MyWebClass.class" file from your development machine (e.g.
C:\EclipseWorkspace\myApp\build\classes\myPackageName\...\My WebClass.class)
to the target machine (e.g.
TOMCAT_HOME/webapps/myApp/WEB-INF/classes/myPackageName/.../ MyWebClass.class).
Restart Tomcat on the target machine and retest until everything is in
order and your Web Services Interfaces are working as required.
11) At this point, using your Java class, you have successfully created
your Web Services Interfaces and their WSDL document - the WSDL document
lives under the TOMCAT_HOME/webapps/myApp/wsdl directory and can be
accessed using the browser via a URL similar to the following:
http://localhost:8080/myApp/services/MyWebClass?wsdl
Using the following URL will show you some other WSDL interfaces created
by Eclipse:
Publishing the WSDL document into the UDDI registry...
Next we want to publish the "myWebClass" WSDL into a UDDI registry/server.
In this example we will be using the jUDDI server that was installed on
our target machine. If the jUDDI server was installed correctly, its main
page should be at a URL similar to the following:
By looking in the "controller.jsp" file that resides under the
TOMCAT_HOME/webapps/juddi/console directory, we can see that the "inquiry"
URL is something like "http://localhost:8080/juddi/inquiry" - we will need
this URL later in the wizard.
1) Bring up Eclipse and do:
2) In the Web Services Explorer window, click on the "UDDI Main" link.
3) For the "Inquiry URL" field enter the jUDDI inquiry URL that you got
from the "controller.jsp" file, e.g.
4) Give the jUDDI server an appropriate name for the "Registry Name"
field, e.g. "My jUDDI", then click on the "Go" button.
5) In the "Registry Details" screen, under "Other Actions", you can click
on the "Add To Favorites" link to add your jUDDI registry server to the
drop down list (for future usage).
6) In the "Registry Details" screen, under "Other Actions", click on the
"Publish" link to bring up the "Publish" screen. Use the following options
to publish the "MyWebApp" services:
- Publish -> Service Interface
- Publication format -> simple
- Publish URL -> http://localhost:8080/juddi/publish
- User ID -> myUserId (this is the user ID that you have allowed to use
the jUDDI database)
- Password -> <I don't believe jUDDI is currently using this field, so you
can enter anything>
- WSDL URL -> platform:/resource/myApp/WebContent/wsdl/MyWebClass.wsdl
- Name -> My Application
- Description -> My Web Class Services
For the "WSDL URL" field, you must use the browse button to select the
myApp project and Eclipse should be able to find the WSDL document from
that project and import it into that field.
Notice that the "Publish URL" is the URL for the jUDDI server's "publish"
address (i.e. where we're publishing the WSDL document) and NOT where the
MyWebClass service interface lives (i.e. not
http://localhost:8080/myApp/services/MyWebClass).
Searching for the Service...
http://localhost:8080/juddi/inquiry or use the drop down list if you had
saved it already.
4) In the "Registry Details" screen, under "Other Actions", click on the
"Find" link to bring up the "Find" screen.
5) Use the following options in the "Find" screen to find your service:
- Search for -> Service Interfaces
- Type of search -> simple
- Name -> My Application (or whatever "Name" you used in step 6 above)
Click on the "Go" button and the information for the "MyWebClass" services
should be displayed. Notice that you can "Edit" certain fields such as the
"WSDL URL" field. You might want to use the actual URL for the Web
Services such as
http://my.host.machine.name:8080/myApp/services/MyWebClass?w sdl instead of
the default one listed in the MySql database, e.g.
"platform:/resource/myApp/WebContent/wsdl/MyWebClass.wsdl"
Re: How to publish to my own jUDDI server? [message #177528 is a reply to message #177457] Sat, 19 August 2006 01:18 Go to previous messageGo to next message
Alan,
this is excellent stuff! Converted to HTML with a few screenshots this would fit very nicely into our set of
tutorials [1]. Would you be interested in transcribing this into a tutorial?
Cheers - CB.
[1] http://www.eclipse.org/webtools/community/communityresources .html#ws
> Cheers - Alan
> Professional.
> 5.0.22-linux-i686:
> before continuing.
> plugin:
> this as follows:
> New->Class
> the class files:
> interface.
> the "Next" button
> to start Tomcat.
> use of it.
> by Eclipse:
> the jUDDI database)
> can enter anything>
> saved it already.
> Services such as
Re: How to publish to my own jUDDI server? [message #177664 is a reply to message #177528] Tue, 22 August 2006 12:02 Go to previous messageGo to next message
Chris Brealey wrote:
> Alan,
> Cheers - CB.
Hi Chris,
How do I go about putting together the html and screenshots for the
tutorial? Does the www.eclipse.org have a set of tools to use for this?
Alan
Re: How to publish to my own jUDDI server? [message #178534 is a reply to message #177664] Tue, 05 September 2006 13:02 Go to previous message
Hi Alan,
thanks.
The contents of the WTP Web site are maintained in CVS, host dev.eclipse.org,
repository path /cvsroot/org.eclipse respectively, under www/webtools. Most of the
actual HTML documents are built from corresponding hand-edited XML documents by a
bunch of stylesheets executed by www/webtools/build.xml. To get to the heart of
the matter, you could:
1. Connect anonymously to dev.eclipse.org:/cvsroot/org.eclipse and check out "www"
(which takes a while).
2. Copy
www/webtools/jst/components/ws/1.5/tutorials/TopDownWebServi ce/TopDownWebService.xml
to, say,
www/webtools/jst/components/ws/1.5/tutorials/WebServicePubli cation/WebServicePublication.xml.
3. Edit WebServicePublication.xml.
4. Run www/webtools/build.xml as Ant.
5. Open WebServicePublication.html in a browser to see how it looks.
6. Repeat at #3 until you're happy.
7. Open a bug and attach your tutorial for me to commit.
If you explore www/webtools/jst/components/ws/1.5/tutorials/ a bit, you should
quickly get the gist of how the tutorials, their screenshots, supporting source
files, etc. are organized. You're welcome to drop me a line directly if you have
any further questions.
Thanks again for your interest - CB.
> > Alan,
> > Cheers - CB.
> Hi Chris,
> Alan
Previous Topic:eclipse-SDK-3.2-win32 and wtp-M-1.5.1-200608241726
Next Topic:Deployment API?
Current Time: Sun Jul 27 07:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.04111 seconds
