Home » Language IDEs » C / C++ IDE (CDT) » Outline View and user-defines data types
Outline View and user-defines data types [message #177143] Fri, 22 September 2006 09:27 Go to next message
Originally posted by: christian.welzel.brosa.net
i have a simple question. Is it possible to display user-defined data types
in the outline view? We have defined several data types, e.g. uint8, uint16.
If there is a function with this data types in the header, outline doesn't
display this function. (E.g. uint8 do_something( void ) ).
I hope, anayone has an answer. Thanks.
Christian
Re: Outline View and user-defines data types [message #177278 is a reply to message #177143] Mon, 25 September 2006 05:31 Go to previous messageGo to next message
Christian Welzel wrote:
> Christian
I'd suggest to disable the option "Follow #include's when parsing
working copies" under Preferences > C/C++.
Disabling this option often improves the usability of the outline view.
If I create a C file containing only the line
uint8 do_something( void ) {}
with the above option enabled, the outline view is empty.
When I disable the option (and force a reconcile by typing some
whitespace), the outline view shows the function.
HTH,
Toni
Anton Leherbauer
Wind River CDT Team, Austria
Re: Outline View and user-defines data types [message #177292 is a reply to message #177143] Mon, 25 September 2006 06:55 Go to previous messageGo to next message
Christian,
I could not reproduce your problem with the following snippet:
typedef char uint8 ;
uint8 getValue() {
return 27 ;
I suggest that you create a minimal example which is reproducable. You can
post it here or even create a bugzilla for this.
Norbert
Re: Outline View and user-defines data types [message #177533 is a reply to message #177278] Thu, 28 September 2006 02:41 Go to previous message
Hi Anton,
this works, but I think this is a bug in CDT.
Thank you,
Christian
"Anton Leherbauer" <anton.leherbauer@windriver.com> schrieb im Newsbeitrag
news:ef87l4$e73$1@utils.eclipse.org...
>> Hi,
>> types in the outline view? We have defined several data types, e.g.
>> uint8, uint16. If there is a function with this data types in the header,
>> outline doesn't display this function. (E.g. uint8 do_something(
>> void ) ).
>> Christian
> I'd suggest to disable the option "Follow #include's when parsing working
> HTH,
> Toni
> Anton Leherbauer
Previous Topic:CDT+Zylin plugins on Eclipse
Next Topic:Extending CDT
Current Time: Mon Nov 10 02:36:29 EST 2025
Powered by FUDForum. Page generated in 0.25006 seconds
