Filtering setup file 'requirement' by Eclipse release (Neon/4.6) [message #1770936] |
Fri, 18 August 2017 18:32  |
Is it possible to make a requirement conditional on the Eclipse IDE release installed? The filter below works fine for checking the OS version for example, but I'm having a hard time finding an available property that will check for something like 'Neon' or '4.6'. Is that currently supported?
<requirement
name="my.feature"
versionRange="[3.0.0,4.0.0)"
filter="(osgi.os=win33)"/>
Re: Filtering setup file 'requirement' by Eclipse release (Neon/4.6) [message #1771093 is a reply to message #1770975] |
Mon, 21 August 2017 16:50   |
Thanks Ed, that sounds like a promising approach. However, I've never been able to get 'optional' to work, as optional features always appear to be ignored (regardless of greedyness). I must be doing something wrong somehow, unless this is a recent regression.
Trying again with Neon.3 and Oxygen, the following requirement appears to be completely ignored (there is nothing interesting logged to the Eclipse error log or to the setup.log):
<requirement
name="my.feature.group"
optional="true"/>
However, after making the requirement required, the feature will install just fine into Oxygen, and will fail under Mars (as expected, due to unfulfilled requirements).
<requirement
versionRange="[3.0.0,4.0.0)"/>
Re: Filtering setup file 'requirement' by Eclipse release (Neon/4.6) [message #1771202 is a reply to message #1771109] |
Tue, 22 August 2017 17:01   |
Yes, it seems unlikely that optional requirements would be broken in p2. I'm assuming that when you talk about greedy, it's in regard to the p2 configuration (p2.inf, or something similar), and not in the oomph setup file, where greedy=true is the default.
I can file an Oomph bug report for this, but would like to check if the following is supposed to work first. I added the following requirement only to an Eclipse Oxygen oomph setup file, for example to installation.setup:
<requirement
name="org.eclipse.cvs.feature.group"
versionRange="[1.4.0,2.0.0)"
optional="true"/>
However, the CVS plugin wasn't installed after restarting Eclipse, and there are no errors logged anywhere AFAIK. 'greedy="true"' should be the default for oomph requirements, while I tried explicitly adding that as well (to no avail).
On the other hand, the following non-optional requirement will install w/o problems:
<requirement
versionRange="[1.4.0,2.0.0)"/>
Is there some p2 greedy setting that would need to be configured for the Eclipse (CVS plugin) update site as well, in order for the oomph 'optional' requirement to work? I chose the CVS plugin example because it's a common plugin hosted by Eclipse.
FUDForum. Page generated in 0.24260 seconds
