Home » Archived » XML Schema Definition (XSD) » Get cvc-complex-type.3.2.2 error in some, but not all, maven POM files
Get cvc-complex-type.3.2.2 error in some, but not all, maven POM files [message #1771151] Tue, 22 August 2017 10:23 Go to next message
I get the following error in two of my maven pom.xml files, but not in other pom.xml files in the same workspace that, as far as I can tell, have identical XML declaration and document element attributes:Quote:
cvc-complex-type.3.2.2: Attribute 'xml:space' is not allowed to appear in element 'project'.
The problem occur in Eclipse Neon with JDK 8 on a Windows 7 machine.
I get the same problem in two separate git worktrees from the same git repository, in two separate eclipse workspaces (indicating that it's probably not something cached in the workspace).
I have also checked the Validation settings in the project properties of the projects that don't fail (in case I had suppressed the error without remembering it), but the "Enable project specific settings" checkbox is unchecked.
The pom.xml files that gets the error, are:
ukelonn.api/pom.xml and ukelonn.bundle/pom.xml
POM Files that don't get the error, are ukelonn.bundle.db.liquibase/pom.xml, ukelonn.bundle.db.test/pom.xml, ukelonn.bundle.db.postgresql/pom.xml, and ukelonn.tests/pom.xml
As far as I can tell the schema location is the same for the files that fail as for the files that don't fail.
One difference is that the ukelonn.api file has <packaging>bundle</packaging> and the ukelonn.bundle has <packaging>war</packaging>, but I can't see how that should affect the XSD validation of the <project> element (and removing <packaging>bundle</packaging> in the ukelonn.api/pom.xml file didn't remove the error).
Does anyone know why I get the error in only two of the pom.xml files, but not in the others?
Thanks!
- Steinar
[Updated on: Tue, 22 August 2017 10:26] by Moderator
Re: Get cvc-complex-type.3.2.2 error in some, but not all, maven POM files [message #1771173 is a reply to message #1771151] Tue, 22 August 2017 11:42 Go to previous message
That message doesn't come from the XSD model's implementation. Likely it's from Xerces. Probably it's better to ask on the Web Tools forum about it.
Previous Topic:XSD Error
Next Topic:XSD assert
Current Time: Sun Jul 27 04:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.04188 seconds
