Home » Modeling » Papyrus » Jave Errors when applying changes to Diagram Properties menu
Jave Errors when applying changes to Diagram Properties menu [message #1770306] Wed, 09 August 2017 16:33 Go to next message
Papyrus Oxygen (4.7.0)
With my project selected in the Project Explorer, I select
Project -> Properties -> Papyrus -> Diagram
which calls up a nice menu for altering things like font, color and grids. However, hitting the Apply button generates an:
"Unhandled event loop exception" error;
while hitting the Apply and Close button generates a:
"[some class] cannot be cast to [some other class]" error.
I've put the full error log entries for these two errors in a text file attached to this post.
In either case, changes I make on this menu are not applied to diagrams I later create. Am I doing something wrong, or have I hit a bug?
Thanks a bunch!
EDIT:
Have confirmed the above behavior with a fresh download of Papyrus + SysML14 (I've attached an image of my Install Details). I didn't even try to actually change the default settings on the Diagram menu this time...just clicked the Apply or Apply and Close buttons, and got the errors. I do not get errors from other Project ->Properties menus.
I'm not quite Java savvy enough to know what I should try next. Any advice is much appreciated.
[Updated on: Thu, 10 August 2017 16:29] by Moderator
Re: Jave Errors when applying changes to Diagram Properties menu [message #1771034 is a reply to message #1770306] Mon, 21 August 2017 07:44 Go to previous messageGo to next message
Thanks for reporting the problem.
This is actually a bug, it has been reported here https://bugs.eclipse.org/bugs/show_bug.cgi?id=518353
Best Regards,
Pauline
Re: Jave Errors when applying changes to Diagram Properties menu [message #1771040 is a reply to message #1771034] Mon, 21 August 2017 08:23 Go to previous message
Thank you Pauline! I must have overlooked that bug report in my initial search.
Previous Topic:Is it possible to put special characters (Greek) in element names?
Next Topic:Can't drag and drop FMU onto Simulator diagram - Moka
Current Time: Sat Jul 26 21:19:54 EDT 2025
Powered by FUDForum. Page generated in 0.16766 seconds
