Home » Modeling » TMF (Xtext) » SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts&
SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts& [message #1770942] Sat, 19 August 2017 03:02 Go to next message
I met a problem when i use my modified xtext project to run "generate xtext artifacts" in a .xtext file. For details info please see the SecurityException.JPG, OperationCauseException.JPG and errormessage.txt.
index.php/fa/30417/0/
As my test, I use the pure xtext source code instead of my modified xtext code, it also has this problem.
only if I use the original org.eclipse.xtext_*.jar, it works.
The exception message shows "signer information does not match signer information of other classes in the same package". But I don't know where the signer information produced.
Can anybody help me?
[Updated on: Sat, 19 August 2017 03:08] by Moderator
Re: SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts [message #1770945 is a reply to message #1770942] Sat, 19 August 2017 04:16 Go to previous messageGo to next message
what is the reason you patch at all?
did you patch both org.eclipse.xtext and org.eclipse.xtext.util bundle?
the signer information is in the manifests
Re: SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts [message #1771013 is a reply to message #1770945] Mon, 21 August 2017 03:59 Go to previous messageGo to next message
HI, Christian Dietrich
I made some modifications in org.eclipse.xtext for Xtext integration with Sirius.
I did not patch org.eclipse.xtext.util, and the XtextSwitch class is in org.eclipse.xtext project, not in org.eclipse.xtext.util project.
I did not modify XtextSwitch, so i don't known how to solve this problem by now.
Re: SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts [message #1771027 is a reply to message #1771013] Mon, 21 August 2017 05:39 Go to previous messageGo to next message
What did you modify ususally you can do everything with guice
Re: SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts [message #1771234 is a reply to message #1771027] Wed, 23 August 2017 03:40 Go to previous message
I fix this problem by "JAR Signing". I export some related jars with "Jar Signing" option, and it works.
Previous Topic:[LSP] IOutputConfigurationProvider is not working with LSP
Next Topic:How to enable running functionality in a new dsl
Current Time: Sat Jul 26 23:34:06 EDT 2025
Powered by FUDForum. Page generated in 0.28813 seconds
