Home » Modeling » TMF (Xtext) » How to use EOL to grammar(Without EOL my rules are overlapping)
How to use EOL to grammar [message #1770686] Wed, 16 August 2017 05:12 Go to next message
I've some old legacy language with many problems... and it seems that only way (with ANTLR) is to use EndOfLine as part of the grammar and in general, make in withe space aware language.
But EOL solves one problem giving 2 back ;)
My problems:
1. Rule MyVarField is defined with list of modifiers (*)
2. When I try to define MyMethod after MyVarField modifiers from MyMethod are parsed as part of MyVarField...
3. With added EOL rule it works better but parser comes with errors like 'missing EOF at \n' or 'no viable alternative at input \n'.
So how bad is my situation? Any hope?
This is a short version of my grammar so far:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
MyModel:
	myElements+=MyElements*;
MyElements:
	MyPackage | MyVarField | MyMethod ;
MyPackage:
	'$package' name=ID EOL+;
MyMethod:
	modifiers+=MyModifiers* name=ID '(' ')' EOL+
	myCommands+=MyCommands*;
MyCommands:
	MyReturn | MyVarField | MySet ;
MySet:
	'set' var=[MyVarField] '=' value=INT;
MyReturn:
	'return' var=[MyVarField];
MyVarField:
	type=('$var'|'$val') name=ID (isArray?='(' ')')? varFieldSettings+=MyFieldSettings* EOL+;
MyFieldSettings:
	MyType | MyModifiers;
MyModifiers:
	modifiers=MyModifiersEnum;
MyModifiersEnum:
	FINAL='final' |
	EXTERNAL='external' |
	INTERNAL='internal' |
	PACKAGE='package' |
	PUBLIC='public' |
	PRIVATE='private';
MyType:
	'type' '=' type=[MyModel];
@Override terminal WS:
	(' ' | '\t')+;
terminal EOL:
	'\r'? '\n';
Re: How to use EOL to grammar [message #1770688 is a reply to message #1770686] Wed, 16 August 2017 05:21 Go to previous messageGo to next message
whats your actual problem/question
are
you asking about this ambiguity:
warning(200): ../org.xtext.example.mydsl3/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:276:3: Decision can match input such as "'$var' RULE_ID '(' ')' 'type' '=' RULE_ID RULE_EOL" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(200): ../org.xtext.example.mydsl3.ide/src-gen/org/xtext/example/mydsl3/ide/contentassist/antlr/internal/InternalMyDsl.g:741:41: Decision can match input such as "'$var' RULE_ID '(' ')' 'type' '=' RULE_ID RULE_EOL" using multiple alternatives: 1, 2
Re: How to use EOL to grammar [message #1770690 is a reply to message #1770688] Wed, 16 August 2017 05:27 Go to previous messageGo to next message
My question is how to define rules MyMethod and MyVarField so they can be used in any order.
Re: How to use EOL to grammar [message #1770691 is a reply to message #1770688] Wed, 16 August 2017 05:28 Go to previous messageGo to next message
thus the question:
MyMethod:
if after the method there are two fields
go they into myCommands or the elements of the parent?
Re: How to use EOL to grammar [message #1770695 is a reply to message #1770691] Wed, 16 August 2017 05:59 Go to previous messageGo to next message
If they are declared as part of myCommads in MyMehod then they are part of MyMethod till next MyMethod declaration, Just like in Python:
MyMethod:
	BEGIN
	END;
terminal BEGIN: 'synthetic:BEGIN';
terminal END: 'synthetic:END';
Sos this should be correct:
$package test
$var testVar public external
// begining of method
public static methodName()
	$var intVal private internal
	return intVal
//end of method
private final method2 ()
	return testVar
// end of method
Re: How to use EOL to grammar [message #1770696 is a reply to message #1770695] Wed, 16 August 2017 06:07 Go to previous messageGo to next message
yes but you dont have begin end thus
maybe
MyMethod:
->myCommands+=MyCommands*;
is what you want
[Updated on: Wed, 16 August 2017 06:07] by Moderator
Re: How to use EOL to grammar [message #1770699 is a reply to message #1770696] Wed, 16 August 2017 06:52 Go to previous messageGo to next message
This will nt solve this problem, as it is removing modifiers (public,static,...) that can be before method name. I can add
MyMethod:
	BEGIN
	END;
to grammar... but anyway example file is not parsed properly.
Still "public internal" from
$var varName // nothing more
public static methodName ()  // public static will be part of varName not methodName()
    return varName
Re: How to use EOL to grammar [message #1770700 is a reply to message #1770699] Wed, 16 August 2017 06:57 Go to previous messageGo to next message
please give a complete grammar and sample model.
you switch between using WS languages and not using them back and forth
Re: How to use EOL to grammar [message #1770701 is a reply to message #1770700] Wed, 16 August 2017 07:01 Go to previous messageGo to next message
Changed grammar:
MyModel:
MyElements:
	MyPackage | MyVarField | MyMethod;
MyPackage:
	'$package' name=ID;
MyVarField:
	'$var' name=ID (isArray?='(' ')')? varFieldSettings+=MyFieldSettings*;
MyMethod:
	modifiers+=MyModifiers*name=ID '(' ')'
	->myCommands+=MyCommands+;
MyCommands:
	MyReturn | MySet | MyType;
MySet:
	'set' var=ID '=' value=INT;
MyReturn:
	'return' var=ID;
MyFieldSettings:
MyModifiers:
MyModifiersEnum:
	FINAL='final' |
	PACKAGE='package' |
	PUBLIC='public' |
	PRIVATE='private';
MyType:
	'type' '=' type=ID;
Sample file:
$package vars
$var varName public external
private final method()
	type = ONE
	return TWO
With this grammar I don't have any parser errors but result is not correct as is parsed as:
$package vars
$var varName public external private final // All in one line
// just that
method()
	type = ONE
	return TWO
Re: How to use EOL to grammar [message #1770703 is a reply to message #1770701] Wed, 16 August 2017 07:12 Go to previous messageGo to next message
i am still get tons of ambiguity errors in the log.
and still the question
where does the field end and where does the method start?
maybe you can try something like
grammar org.xtext.example.mydsl5.MyDsl with org.eclipse.xtext.common.Terminals hidden(SL_COMMENT, ML_COMMENT, WS, EOL)
MyVarField hidden(WS):
(' ' | '\t')+;
terminal EOL:
'\r'? '\n';
this grammar now has no EOL nor WHITESPACE at all
maybe something like this works for you
Re: How to use EOL to grammar [message #1770716 is a reply to message #1770703] Wed, 16 August 2017 08:56 Go to previous message
Now is much better :)
I'm able to correctly parse this model:
$package vars
$var varName public external //test
$var var2Arr() private internal
public final method1()
	type = String
	set var = 123
private final method2()
	return Var
Without any errors in Error log or parser errors.
Just on top of your changes I changed this:
	'$var' name=ID (isArray?='(' ')')? varFieldSettings+=MyFieldSettings* (EOL | SL_COMMENT)+;
to add some kind of separator as varFieldSettings was still mixed with modifiers list
Thank you for help
Previous Topic:Multiple Sort Contributions (or Comparators) in Outline
Next Topic:<MyDSL>TerminalsValidator class not being generated
Current Time: Fri Jul 25 23:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.08470 seconds
