Home » Modeling » TMF (Xtext) » Multiple Sort Contributions (or Comparators) in Outline(How to implement multiple contributions sorting the outline differently)
Multiple Sort Contributions (or Comparators) in Outline [message #1770617] Tue, 15 August 2017 04:17 Go to next message
I want to add a contribution to the outline view sorting the elements of the outline differently from the default alphabetic sort.
The following classes are involved in the implementation:
  • org.eclipse.xtext.ui.editor.outline.actions.SortOutlineContribution
  • org.eclipse.xtext.ui.editor.outline.impl.OutlineFilterAndSorter.IComparator
  • my.language.UIModule: binding or configuring the contributions or comparators
I have already written some filter contributions, they are all implemented by subclassing
org.eclipse.xtext.ui.editor.outline.actions.AbstractFilterOutlineContribution. But how to I add a new sort contribution, based on the SortOutlineContribution?
Ideally I want to only write a new comparator. I already did that and using
public Class<? extends IComparator> bindOutlineFilterAndSorter$IComparator() {
	return MyComparator.class;
I can replace the default (pure lexicographic) comparator. But I don't want to replace it, I want to add it.
Apparently I need to write a new contribution, since a text, description and icon are required not provided by the comparator only. Unfortunately the SortOutlineContribution doesn't look like being designed for re-use.
For filter contributions, I need to bind them as follows in the UIModule:
public void configureMyFilterOutlineContribution(Binder binder) {
	binder.bind(IOutlineContribution.class).annotatedWith(
		Names.named("MyFilterOutlineContribution")
	).to(MyFilterOutlineContribution.class);
Is there something similar for sorting? But where do the text and icon come from then?
What do you recommend?
Jens
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770618 is a reply to message #1770617] Tue, 15 August 2017 04:33 Go to previous messageGo to next message
the data comes from org.eclipse.xtext.ui.editor.outline.actions.SortOutlineContribution.configureAction(Action)
so copy&paste / subclass should work + adding an artificial binding with an artifical named key should do the trick
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770619 is a reply to message #1770618] Tue, 15 August 2017 04:39 Go to previous messageGo to next message
Unfortunately it is not that easy: The multiple sort contributions need to be aware of the other. That is, only one of them must be active at a time. Seems as if the framework is not prepared for that, is it?
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770621 is a reply to message #1770619] Tue, 15 August 2017 04:48 Go to previous messageGo to next message
Seems so.
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770622 is a reply to message #1770619] Tue, 15 August 2017 04:49 Go to previous messageGo to next message
Actually, the framework does not support multiple comparators, cf org.eclipse.xtext.ui.editor.outline.impl.OutlineFilterAndSorter:
It is possible to add (or remove) filters (plural!), but only one comparator can be set.
So it may be possible to write a special comparator that can be configured by multiple contributions, but I'm not sure its worth the effort (at least for me). So I will stick to simply replacing the original comparator.
But if someone has a better (or already working solution), I would be very interested in that.
Jens
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770623 is a reply to message #1770622] Tue, 15 August 2017 04:59 Go to previous messageGo to next message
can you file an enhancement request for that.
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770624 is a reply to message #1770623] Tue, 15 August 2017 05:03 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 15 August 2017 10:59
Well, there are so many other much more sever issues open, that I'm reluctant to add an enhancement request for something that rather unimportant ;-)
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770625 is a reply to message #1770624] Tue, 15 August 2017 05:04 Go to previous messageGo to next message
yes but this is something a beginner could easily work on
Re: Multiple Sort Contributions (or Comparators) in Outline [message #1770628 is a reply to message #1770625] Tue, 15 August 2017 05:21 Go to previous message
Good point. Created issue: https://github.com/eclipse/xtext-core/issues/423
Previous Topic:XText 2.12 blocking issues with Large Grammars
Next Topic:How to use EOL to grammar
Current Time: Sun Jul 27 09:45:13 EDT 2025
Powered by FUDForum. Page generated in 0.04150 seconds
