Home » Eclipse Projects » Model Driven Health Tools » CCDA CCD (2.1) fails to validate on ETT(CCDA 2.1 fails to validate because observation text and value elements are showing up before templateids)
CCDA CCD (2.1) fails to validate on ETT [message #1770460] Fri, 11 August 2017 16:35 Go to next message
The Observation's text/value elements are showing up first before the template ids causing validation errors on the ttpedge.
Error - cvc-complex-type.2.4.a: Invalid content was found starting with element 'text'. One of '{"urn:hl7-org:v3":realmCode, "urn:hl7-org:v3":typeId, "urn:hl7-org:v3":templateId, "urn:hl7-org:v3":id, "urn:hl7-org:v3":code}' is expected.
CCDA:
<observation classCode="OBS" moodCode="EVN" negationInd="false">
<text><reference value="#PROB_1"/></text>
<value xsi:type="CD" code="230684008" codeSystem="2.16.840.1.113883.6.96" codeSystemName="SNOMEDCT" displayName="Ocular myasthenia (disorder)">
<originalText><reference value="#PROB_1"/></originalText>
</value>
<templateId root="2.16.840.1.113883.10.20.22.4.4" extension="2015-08-01"/>
<templateId root="2.16.840.1.113883.10.20.22.4.4"/>
Is anyone else experiencing this or is it just me?
Re: CCDA CCD (2.1) fails to validate on ETT [message #1770484 is a reply to message #1770460] Sat, 12 August 2017 09:23 Go to previous messageGo to next message
This does appear to be an issue the EMF serialization - I will look to update asap;
Re: CCDA CCD (2.1) fails to validate on ETT [message #1770726 is a reply to message #1770460] Wed, 16 August 2017 09:52 Go to previous messageGo to next message
Thanks for taking a look. Do you have a time frame for when the fix will be applied?
Re: CCDA CCD (2.1) fails to validate on ETT [message #1770830 is a reply to message #1770460] Thu, 17 August 2017 09:18 Go to previous messageGo to next message
I was just going to make a post about this same issue...then I found this where it was already been asked. Can anyone post some workarounds on this ? Is there any probable date for fixing this issue ?
Re: CCDA CCD (2.1) fails to validate on ETT [message #1770889 is a reply to message #1770830] Fri, 18 August 2017 08:25 Go to previous messageGo to next message
We have a workaround - use the following CDA Jar locally should fix the ordering issue
https://hudson.eclipse.org/mdht/job/MDHT-master/lastSuccessfulBuild/artifact/repository/plugins/org.eclipse.mdht.uml.cda_3.0.0.201708180504.jar.pack.gz
Re: CCDA CCD (2.1) fails to validate on ETT [message #1770890 is a reply to message #1770830] Fri, 18 August 2017 08:26 Go to previous message
Previous Topic:Misplaced suncomponents
Next Topic:Pre-Caching Enhacement - MDHT
Current Time: Tue May 13 05:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.03296 seconds
