Home » Modeling » TMF (Xtext) » Xbase.genmodel is unmapped while running .mwe2 workflow
Xbase.genmodel is unmapped while running .mwe2 workflow [message #1770242] Wed, 09 August 2017 06:16 Go to next message
Hi, I've an Xtext project and I'm trying to lunch the mwe2 workflow through an external command line .jar using
Mwe2Launcher.main(new String[]{"path/to/file.mwe2"});
and this is the output I get:
0    [main] INFO  text.xtext.generator.XtextGenerator  - Initializing Xtext generator
8    [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
68   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl/'
68   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl.tests at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl.tests/'
69   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl.ide at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl.ide/'
69   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl.ui at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl.ui/'
69   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl.ui.tests at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl.ui.tests/'
69   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.webdsl.web at 'file:/Users/valent0ne/Projects/EclipseWorkspace/org.xtext.webdsl.parent/org.xtext.webdsl.web/'
78   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
100  [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Problems running workflow org.xtext.webdsl.GenerateWebDsl: java.io.IOException: The path '/org.eclipse.xtext.xbase/model/Xbase.genmodel' is unmapped
java.lang.RuntimeException: Problems running workflow org.xtext.webdsl.GenerateWebDsl: java.io.IOException: The path '/org.eclipse.xtext.xbase/model/Xbase.genmodel' is unmapped
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
if I run the mwe2 workflow by right clicking on the .xtext file inside eclipse I get no errors.
This is the content of the .mwe2 file I'm using:
module org.xtext.webdsl.GenerateWebDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.webdsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				web = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				lineDelimiter = "\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.webdsl.WebDsl"
			fileExtensions = "webdsl"
			serializer = {
				generateStub = false
			validator = {
				composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Re: Xbase.genmodel is unmapped while running .mwe2 workflow [message #1770389 is a reply to message #1770242] Thu, 10 August 2017 12:02 Go to previous messageGo to next message
hi,
are you sure all required stuff is on the classpath of that main?
Re: Xbase.genmodel is unmapped while running .mwe2 workflow [message #1770576 is a reply to message #1770389] Mon, 14 August 2017 11:47 Go to previous message
I think so :D
By the way I managed to solve using maven, thanks anyway.
Previous Topic:Execution order of different Validators
Next Topic:XText 2.12 blocking issues with Large Grammars
Current Time: Sun Jul 20 21:19:42 EDT 2025
Powered by FUDForum. Page generated in 0.23807 seconds
