Home » Modeling » TMF (Xtext) » XText 2.12 blocking issues with Large Grammars(Workflow Errors block the ability to generate the infrastructure)
XText 2.12 blocking issues with Large Grammars [message #1770309] Wed, 09 August 2017 17:49 Go to next message
Hi there,
I'm working with Xtext 2.12 to try and create a DSL with a fairly large grammar. At first, I wasn't able to generate the infrastructure at all due to jvm out of memory errors. I was able to fix this by increasing the heap size in the jvm to 2gb via the flag -Xms2g (1 gig wasn't enough).
Anyway, after this I was able to generate the grammar, but the resulting files had errors as follows:
    In my XxxxParser.java file - "The code of constructor x() is exceeding the 65535 bytes limit."
    and in my InternalXxxxParser.java file "Too many constants, the constant pool for InternalXxxxParser would exceed 65536 entries."
Reading a few other posts led me to find Bug 34992 , which I read and mostly understood. ;-) Based on the recommendations in that ticket, I tried adding the following to my workflow:
fragment = parser.antlr.XtextAntlrGeneratorFragment2 auto-inject {
    combinedGrammar = true // <-- I tried both true and false here.  No luck.
    options = {
        classSplitting=true
        fieldsPerClass = "500"
Note, the writeup in that ticket calls for using both parser.antlr.XtextAntlrGeneratorFragment and parser.antlr.XtextAntlrUIGeneratorFragment. However, neither of those classes are available to use, and parser.antlr.XtextAntlrGeneratorFragment2 is the closest thing I could find. Is there a replacement for parser.antlr.XtextAntlrUIGeneratorFragment?
Anyway, after adding the fragment above, the workflow is now failing with the following error:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: XtextGenerator)
	 java.lang.IllegalStateException: The given EMF object already contains an adapter for CombinedGrammarMarker
	at org.eclipse.xtext.xtext.generator.parser.antlr.CombinedGrammarMarker.attachToEmfObject(CombinedGrammarMarker.java:66)
	at org.eclipse.xtext.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment2.doGenerate(XtextAntlrGeneratorFragment2.java:148)
	at org.eclipse.xtext.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment2.generate(AbstractAntlrGeneratorFragment2.java:109)
	at org.eclipse.xtext.xtext.generator.CompositeGeneratorFragment2.generate(CompositeGeneratorFragment2.java:50)
	at org.eclipse.xtext.xtext.generator.XtextGenerator.invokeInternal(XtextGenerator.java:230)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
I don't fully understand the error, but since it's complaining about a duplicate adapter for "CombinedGrammarMarker" I tried twiddling the "combinedGrammar" flag in my config, but neither setting it to true nor false made any difference.
What do I have to do to get around these 64k errors?
    - In my xxxParser.java file - "The code of constructor x() is exceeding the 65535 bytes limit."
    - and in my InternalXxxParser.java file "Too many constants, the constant pool for InternalHtmlParser would exceed 65536 entries."
If using classSpliting = true is no longer supported, what else can I do? If this is still the correct way to get around these issues, what am I missing?
Thanks!
Re: XText 2.12 blocking issues with Large Grammars [message #1770310 is a reply to message #1770309] Wed, 09 August 2017 17:54 Go to previous messageGo to next message
The right section to put that stuff
Is.
parserGenerator = {
You should play with other stuff like methods per class as well.
If this does not help it would be interesting to have
A (if not possible synthetic ) reproducible grammar
Re: XText 2.12 blocking issues with Large Grammars [message #1770313 is a reply to message #1770309] Wed, 09 August 2017 18:15 Go to previous messageGo to next message
One quick update. I switched from using StandardLanguage to using XtextGeneratorLanguage in my workflow, and now the classSplitting=true option is working without throwing the exception. However, this only seems to solve one of my problems:
    Solved - In my InternalXxxParser.java file "Too many constants, the constant pool for InternalHtmlParser would exceed 65536 entries."
    Not Solved - In my XxxxParser.java file - "The code of constructor x() is exceeding the 65535 bytes limit."
Any advice how to get that constructor under control? I tried setting some of the other options in the XtextAntlrGeneratorFragment2:
fragment = parser.antlr.XtextAntlrGeneratorFragment2 {
    options = {
        classSplitting = true
        casesPerSpecialStateSwitch= "200"
        fieldsPerClass = "200"
        methodsPerClass = "200"
but none of these options helped.
Re: XText 2.12 blocking issues with Large Grammars [message #1770314 is a reply to message #1770309] Wed, 09 August 2017 18:15 Go to previous messageGo to next message
    options = {
Re: XText 2.12 blocking issues with Large Grammars [message #1770315 is a reply to message #1770314] Wed, 09 August 2017 18:24 Go to previous messageGo to next message
I don't know if the code in the generator has a splitting strategy for the constructor
You would have to digg into that code
Re: XText 2.12 blocking issues with Large Grammars [message #1770316 is a reply to message #1770315] Wed, 09 August 2017 18:30 Go to previous messageGo to next message
can you give some hints how the big contructor looks like?
is it the one that populates the hashmap?
[Updated on: Wed, 09 August 2017 18:32] by Moderator
Re: XText 2.12 blocking issues with Large Grammars [message #1770318 is a reply to message #1770316] Wed, 09 August 2017 18:39 Go to previous messageGo to next message
if it is the nameMappings map you should file a ticket at github.com/eclipse/xtext-core
i have no idea how to solve this
(depending on how much you are above the limit you may save some bytes by changing the grammar - using shorter names etc)
Re: XText 2.12 blocking issues with Large Grammars [message #1770329 is a reply to message #1770318] Thu, 10 August 2017 01:28 Go to previous messageGo to next message
the following generation pattern would fix the issue
	protected String getRuleName(AbstractElement element) {
		if (nameMappings == null) {
			nameMappings = new HashMap<AbstractElement, String>() {
				private static final long serialVersionUID = 1L;
					fillMap0();
					fillMap1();
					fillMap2();
					fillMap3();
				private void fillMap0() {
					put(grammarAccess.getGreetingAccess().getGroup(), "rule__Greeting__Group__0");
					put(grammarAccess.getModelAccess().getGreetingsAssignment(), "rule__Model__GreetingsAssignment");
					put(grammarAccess.getGreetingAccess().getName1Assignment_1(), "rule__Greeting__Name1Assignment_1");
				private void fillMap1() {
					put(grammarAccess.getGreetingAccess().getName2Assignment_2(), "rule__Greeting__Name2Assignment_2");
					put(grammarAccess.getGreetingAccess().getName3Assignment_3(), "rule__Greeting__Name3Assignment_3");
					put(grammarAccess.getGreetingAccess().getName4Assignment_4(), "rule__Greeting__Name4Assignment_4");
				private void fillMap2() {
					put(grammarAccess.getGreetingAccess().getName5Assignment_5(), "rule__Greeting__Name5Assignment_5");
					put(grammarAccess.getGreetingAccess().getName6Assignment_6(), "rule__Greeting__Name6Assignment_6");
					put(grammarAccess.getGreetingAccess().getName7Assignment_7(), "rule__Greeting__Name7Assignment_7");
				private void fillMap3() {
					put(grammarAccess.getGreetingAccess().getName8Assignment_8(), "rule__Greeting__Name8Assignment_8");
					put(grammarAccess.getGreetingAccess().getName9Assignment_9(), "rule__Greeting__Name9Assignment_9");
					put(grammarAccess.getGreetingAccess().getName0Assignment_10(), "rule__Greeting__Name0Assignment_10");
		return nameMappings.get(element);
Re: XText 2.12 blocking issues with Large Grammars [message #1770379 is a reply to message #1770329] Thu, 10 August 2017 11:18 Go to previous messageGo to next message
It is in-fact the constructor of the HashMap, and I've been manually using this exact pattern to manually fix it. I'll file a bug later today, when I have some time.
So, since we all seem to be on the same page, anyone care to point me at towards the code that generates this? I'd be happy to try and fix it myself, and submit a PR ;-)
Re: XText 2.12 blocking issues with Large Grammars [message #1770380 is a reply to message #1770329] Thu, 10 August 2017 11:18 Go to previous messageGo to next message
It is in-fact the constructor of the HashMap, and I've been using this exact pattern to manually fix it after each workflow run. I'll file a bug later today, when I have some time.
Re: XText 2.12 blocking issues with Large Grammars [message #1770381 is a reply to message #1770380] Thu, 10 August 2017 11:22 Go to previous messageGo to next message
PS. I've found that breaking this into 2000 line functions seems to do the trick ;-)
Re: XText 2.12 blocking issues with Large Grammars [message #1770382 is a reply to message #1770381] Thu, 10 August 2017 11:24 Go to previous messageGo to next message
Can you please file an issue
Re: XText 2.12 blocking issues with Large Grammars [message #1770396 is a reply to message #1770382] Thu, 10 August 2017 12:58 Go to previous messageGo to next message
Issue filed. https://github.com/eclipse/xtext-core/issues/419
Re: XText 2.12 blocking issues with Large Grammars [message #1770397 is a reply to message #1770396] Thu, 10 August 2017 13:03 Go to previous messageGo to next message
thank you
Re: XText 2.12 blocking issues with Large Grammars [message #1770407 is a reply to message #1770397] Thu, 10 August 2017 18:10 Go to previous messageGo to next message
Thank you for your quick response. I see you've already submitted a PR with a fix for this issue. Thank you very much! :-)
Re: XText 2.12 blocking issues with Large Grammars [message #1770570 is a reply to message #1770407] Mon, 14 August 2017 11:06 Go to previous messageGo to next message
Wow, this has been an interesting thread., thanks for posting it. I can see this kind of problems coming on me because I'm also manipulating a very large grammar and I've already had out-of-memory-errors :/
Re: XText 2.12 blocking issues with Large Grammars [message #1770626 is a reply to message #1770570] Tue, 15 August 2017 05:12 Go to previous message
We also have a rather large grammar (JavaScript with types) and a lot of fancy features. For that we had to "massage" the generation process quite a bit. If you are interested in that, have a look at
https://github.com/eclipse/n4js/blob/master/plugins/org.eclipse.n4js/src/org/eclipse/n4js/GenerateN4JS.mwe2
as a starting point. The customized generator stuff can be found at
https://github.com/eclipse/n4js/tree/master/releng/org.eclipse.n4js.releng.utils/src/org/eclipse/n4js/antlr
I have explained some of that stuff at an EclipseCon talk in 2013: https://www.youtube.com/watch?v=Xm-7aE1UMGY&feature=youtu.be
Jens
Previous Topic:Xbase.genmodel is unmapped while running .mwe2 workflow
Next Topic:Multiple Sort Contributions (or Comparators) in Outline
Current Time: Sat Jul 26 23:44:02 EDT 2025
Powered by FUDForum. Page generated in 0.12365 seconds
